What did you do to your X308 Today?
Old Apr 22, 2013 | 08:00 PM
  #261
pdupler's Avatar
Removed the cowl, sanded and repainted it. Funny how there was little sun damage anywhere else on the car. Easy job tho. About the last cosmetic item will be to have the drivers side seat bolster repaired. I already have a piece of matching leather, just need to find time to drop it off at the trimmers.
Old Apr 25, 2013 | 11:13 AM
  #262
Robskilling's Avatar
Default Console Lid
Hi all, I'm looking to switch the console lid/armrest of my '98XJR from non cup holder to cup holder - it would seem to be a straight swap. Does anyone know if it is and if its as straight forward as it looks?
Old Apr 27, 2013 | 05:10 AM
  #263
L80ous's Avatar
Replaced disfaced trunk release button with new one, its the little things that count
Attached Thumbnails What did you do to your X308 Today?-20130426_174512.jpg   What did you do to your X308 Today?-20130426_195420.jpg
Old Apr 27, 2013 | 05:48 PM
  #264
Ipc838's Avatar
L80OUS, that looks great!
Old Apr 27, 2013 | 06:26 PM
  #265
Tirefriar's Avatar
The devil is in the details
Old Apr 27, 2013 | 06:32 PM
  #266
Tirefriar's Avatar
Default Broken antenna mast
When I bought my XJR, it's antenna mast would not retract all the way. Bought one on eBay and checked this forum on antenna r&r how to. The explanations made the whole operation a breeze. I had a friend turn the radio on and off to help with install. This forum is great! P.s. my next project is to tackle telescoping steering wheel issue. After I fix that, the car will be perfect!
Old Apr 27, 2013 | 06:48 PM
  #267
XJR Prototype's Avatar
I posted in my build thread.
Old Apr 27, 2013 | 07:09 PM
  #268
giblet's Avatar
Dropped it off at a specialists for a service and a once over. Once its done I'll start working on the long list of things to do.
Old Apr 27, 2013 | 08:50 PM
  #269
Safi's Avatar
my car created an exhaust leak
Old Apr 27, 2013 | 10:48 PM
  #270
xjay8's Avatar
A straight forward job Rob ;o)
just be careful witht he little screws that hold the check arm to bottom of the armrest.
The arm rest is held on to the centre console with screws at the hinge end.
Just make sure you choose one that has a working cup holder....a great majority of which are useually broken by some ham fisted klutz ;o))
make sure when you replace it that the arm rest is aligned squarely and operates the catch properly ;o))
Old Apr 27, 2013 | 10:52 PM
  #271
xjay8's Avatar
Did you check the functipon of the rest of the mechanism while you were aty it?
Use the key and lubricate the key mechanism with electronic spray cleaner
and check the wiring.
That's a gorgeous colour what's it called?
Old Apr 27, 2013 | 11:04 PM
  #272
plums's Avatar
Originally Posted by Blue_XJ8
Here are some pics to demonstrate my rotor replacement :-)
In the second picture, that is not uneven wear on the pads. That is a chamfer cut into all pads as new.
Old Apr 29, 2013 | 04:13 PM
  #273
Cool, thanks, won a replacement on eBay today so just await its arrival then fit! Chuffed to bits!
Old Apr 29, 2013 | 07:13 PM
  #274
pdupler's Avatar
Done!
Old Apr 30, 2013 | 08:40 AM
  #275
Probesport's Avatar
re-dyed the steering wheel leather
https://www.jaguarforums.com/forum/i...ts-90629/page2
Old Apr 30, 2013 | 04:46 PM
  #276
Vector's Avatar
Default Cleaned my wheel speed sensors!
https://www.jaguarforums.com/forum/x...66/#post728355
Vector
Old May 1, 2013 | 02:44 PM
  #277
L80ous's Avatar
Yes checked the function of the new unit before I put it back together but as it was all worked smootly already there wasnt much more to it just was only replaced due to cosemics.
The colour is Carnival Red
Old May 4, 2013 | 07:10 PM
  #278
Safi's Avatar
realigned the boot lid, finally she looks nearly perfect
Old May 5, 2013 | 03:47 PM
  #279
Tirefriar's Avatar
Default Finally
Finally got around to installing RealGauge after it sat on my shelf since last December. Amazed at how straight forward the instal was. I uploaded instructions on my iPad for easy follow. I opted not to put numbers on the gauge face. Took me several hours because I cleaned every part plus double and triple checked all wires before splicing. BTW, I had a clanking notice coming from what I thought was the steering wheel. Turned out the sound was made by lose clip retainers for the wood front cluster trim. Strongly recommend. Perhaps the Least expensive and most sensible upgrade you can do for your X308.
Old May 5, 2013 | 04:23 PM
  #280
giblet's Avatar
Gave my XJR it's first wash under my ownership. Took me 3 hours for a pre wash, foam, 2 bucket wash, clay, another wash and then a dry. It looks a darn sight better now, just need to give it a polish and then a good coat of wax next.
