What did you do to your X308 Today?
Old May 9, 2014 | 11:46 AM
  #681
Probesport's Avatar
This is the one I use, a buddy who does custom automotive and bike painting uses the same. Wonderful machines.
Makita polisher Makita polisher
Old May 9, 2014 | 12:34 PM
  #682
Forcedair1's Avatar
Originally Posted by Badbenz94
Too ordered led's for the inner lamps and hope to have them by Tuesday and hopefully will match the headlights better than the yellow glow( relatively) the 194s give off.
Chris
The inner lamps are the high beam, do LED's work for a high beam application?
Actually, first question: Is this an X308?
Last edited by Forcedair1; May 9, 2014 at 12:36 PM. Reason: Confirming what car we're talking about
Old May 9, 2014 | 12:44 PM
  #683
Probesport's Avatar
Since he mentioned 194's I am assuming that he is referring to the city or twinkle lights in the high beam housings. I have 194 LED's in there as well.
Old May 9, 2014 | 01:03 PM
  #684
Forcedair1's Avatar
Lately, the "ASC unavailable" warning had began popping up and throwing the car into limp mode almost every time I drove the car.
Removed all four wheels speed sensors, washed them, fully dried and inspected. Cleaned and inspected the mating connectors at the wheels. Also, checked all sensors from the ABS plug in the engine compartment, as to confirm the entire sensor circuit integrity. Resistance on each sensor read 1,100 ohms (2002 XJR).
It appears that the fault is now gone because the last drives before I worked on this the warning was popping up within a minute or two. Not the case anymore.
Old May 9, 2014 | 01:20 PM
  #685
Badbenz94's Avatar
Yes that's what I meant. The LEDs are too blue looking for me( at least in the garage, haven't tried then in total darkness) and somehow have a constant power source, no key in ignition but they glow ever so faintly. The standard 194s dont do that. What did you do and what color does yours give off.
Thanks!
Chris
Old May 9, 2014 | 01:43 PM
  #686
Probesport's Avatar
I used canbus/error free LED's which have a higher resistance that will stop your faint glow. Most DC systems always have residual current available and LED's draw so little power that they light up a bit.
Mine are quite white and match my LED fogs and HID lows. I use these ones
Inside the car I uses resistors for cabin lighting.
Old May 9, 2014 | 02:30 PM
  #687
Badbenz94's Avatar
Thanks!
Just ordered a set, let you know how they come out.
Chris
Old May 9, 2014 | 06:24 PM
  #688
Badbenz94's Avatar
Well got the car ready for my son for junior prom, these are some crappy cell phone pics and its needs a polish and some dents removed, but my son sees none of that and just see a great looking car he can't wait to take his date in
This pic is from a couple days ago, headlights pulled for cleaning and notice the missing front splitter and drivers side fog lamp(gone since 09). My son said the lack of headlights looks bad a@@! He suggested plastidipping the surrounds and getting dark film for the headlamps....
And here is how she is ready for some fun!
Chris
Attached Thumbnails What did you do to your X308 Today?-685164a5-47a9-4dcd-9960-c60a921bb91f.jpg   What did you do to your X308 Today?-d947e229-ee27-4336-8be2-91ba56c9e8a5.jpg   What did you do to your X308 Today?-4ebd7670-a1d1-4099-94c8-a39fc55a9b74.jpg
Old May 9, 2014 | 07:32 PM
  #689
King Charles's Avatar
Very nice Bab, enjoy !
Old May 9, 2014 | 08:00 PM
  #690
bigcat777's Avatar
She's looks great Chris.
Old May 10, 2014 | 10:46 AM
  #691
Forcedair1's Avatar
Very nice looking XJR.. Most likely the best looking car at the prom...
Cheers,
Old May 10, 2014 | 12:38 PM
  #692
bigcat777's Avatar
Yesterday had two extra keys made for the car. Only had one, just needed the security of more than one key...I feel soooo much better now.
Old May 10, 2014 | 02:57 PM
  #693
Forcedair1's Avatar
Where did you get them?
Where did you have them programmed?
Price each, if you don't mind?
Thank you
Cheers,
Old May 10, 2014 | 04:33 PM
  #694
bigcat777's Avatar
Ebay for the keys. $31.00 for the pair. New. I asked the dealer to cut them and program, but they said they don't cut, but will program. I did ask them who they used for cutting. Called the locksmith, he met me where I wanted. Cut the keys and programed them right there. Tested and worked perfectly. Cutting and programing for both cost me $100.00 plus tax. Cheap date. I recommend using local locksmith that can cut these type of keys, also from what tech said they must be able to program to be sure the key works. I looked like he was using an OBD reader too. I hope this helps. Can't believe I waited so long to do it. I remember the dealer was charging a lot, maybe $200.00 plus for one key.
Old May 10, 2014 | 05:24 PM
  #695
Forcedair1's Avatar
OK, you said "the locksmith, he met me where I wanted. Cut the keys and programed them right there". Sounds like the locksmith did both, cutting and programming? Or, did the locksmith come to the dealer to meet you, cut the keys for you and then you turned to the dealer for the programming part, is this correct?
If cutting and programming cost you $100.00 for both, how much was each job? I just want to make sure that the dealer here doesn't try to rip me off.
Indeed, you've done great. I've waited forever, myself, living with just one key and risking major trouble in doing so. I always thought that programming the key was a very expensive dealer service, so I simply procrastinated.
Thanks for the great info.
Cheers,
Old May 10, 2014 | 06:21 PM
  #696
bigcat777's Avatar
Yes. The locksmith did both, cutting and programing. So he charged me $80.00 for the fist key and then $20.00 for the second. The dealer told me I had to bring them the cut keys because they were the only ones to program, not true. I saved a fortune by just using the locksmith. Good luck my friend, and yes you will feel great relief with more than one key.
Old May 10, 2014 | 06:26 PM
  #697
ragman1171's Avatar
I've been slacking at the updates that I've completed with Hope over the last week or so, but this morning I added some license plate beauty rings. It just looked too plain without them. I took a few pics.
Attached Thumbnails What did you do to your X308 Today?-jag-license-plate-covers-1-.jpg   What did you do to your X308 Today?-jag-license-plate-covers-2-.jpg   What did you do to your X308 Today?-jag-license-plate-covers-3-.jpg   What did you do to your X308 Today?-jag-license-plate-covers-4-.jpg   What did you do to your X308 Today?-jag-license-plate-covers-5-.jpg
Old May 12, 2014 | 12:49 PM
  #698
Badbenz94's Avatar
Cheers,
Thank you King Charles, bigcat and Forcedair! I cant wait to get a polisher and get her to really shine.
He enjoyed the car and prom. Too from what I saw, besides the limos of course(for the seniors there), he had the sharpest car there imo.
Chris
Old May 12, 2014 | 03:45 PM
  #699
Forcedair1's Avatar
Your info is greatly appreciated!
I will proceed with this, finally.
Cheers,
Old May 12, 2014 | 03:56 PM
  #700
Forcedair1's Avatar
I replaced my broken radio. My nice Kenwood kicked the bucket, so this time I installed a head unit with a 5.3" video display. Of course, my ICE system is a complex system, so the radio is just a link in the ICE chain, but I just wanted to say what I've done to my X308 lately.
Attached Thumbnails What did you do to your X308 Today?-cimg2467.jpg   What did you do to your X308 Today?-cimg2491-reduced.jpg
