What did you do to your X308 Today?
Old Sep 19, 2016 | 03:51 PM
  #1641
justinhill's Avatar
What did I do to my XJ8 today? I took it to its third MOT in a week. And it failed again.
Old Sep 28, 2016 | 09:46 AM
  #1642
4litre's Avatar
Originally Posted by greverrr
Friday evening pile up and drive 3 hours to VT for British Invasion 2016. Saturday AM serpentine belt split in two less than a mile into the trip to show, turn around and find another way to the show! Last night finally get off my a$$ to change belt and drive home 3hrs today trouble free. Come to find the belt that split in two was the longer 2000up belt length. Aye yay yay, all set now.
Incredible ride and love the vids! Very useful mod, the hood vents! The XJR should have those from the factory.
Old Sep 28, 2016 | 04:00 PM
  #1643
justinhill's Avatar
What did I do to my XJ8 today? I pulled off the motorway following a horrible noise and found myself dragging the broken pieces of my black undertray out from under the front of the car and putting them in the boot.
Old Sep 28, 2016 | 05:54 PM
  #1644
4litre's Avatar
After the hose replacement, I still have a leak somewhere...got to go back in to the other hoses and check where the leak is. 😭
Old Sep 29, 2016 | 12:03 PM
  #1645
4litre's Avatar
Found the leak, right behind the new heater hose I just replaced at the large norma connector...going to hardware store for bits to fix...
Old Sep 29, 2016 | 01:14 PM
  #1646
Mark Murphy's Avatar
Hi everyone, front sill welding almost finished, only got it yesterday.
Old Sep 29, 2016 | 09:57 PM
  #1647
4litre's Avatar
...it was that norma coupler/tee indeed...replaced with metal one...and, that's that!!
Old Oct 2, 2016 | 09:02 AM
  #1648
convincor's Avatar
Default Wife finally caved
Traded in her Navigator and brought home a mate for my XJR's..
Attached Thumbnails What did you do to your X308 Today?-img_20161002_095315917.jpg
Old Oct 3, 2016 | 09:06 PM
  #1649
greverrr's Avatar
Congrads!
Old Oct 3, 2016 | 09:46 PM
  #1650
JTsmks's Avatar
you bought a Camary? Sorry! Couldn't resist!
Old Oct 4, 2016 | 04:03 AM
  #1651
ericjansen's Avatar
Re-assured the relationship after a couple of months of little problems.
She did great today on a 120km coastal tour, I am in love again .
Old Oct 4, 2016 | 09:08 PM
  #1652
nilanium's Avatar
Poly front shock mount bushing kit. Pretty minor but I'd rather not risk getting dinged on disintegrating foam in the safety inspection. Found a dead wasp nest under the drivers' shock mount plate.
Also found an XJR in my local junkayrd, for probably the first time ever. Went to go pull the wheels off, and in the 3 days between the car showing up at the yard and me getting there, the recyclers had gone through that section of the yard and pulled all the wheels. I saw the full set of clean Pentas sitting on the top of the recycler's dumpster, where only the recyclers are allowed access to.
At least they left the full set of Penta lugnuts, which seem to be even harder to find than cheap factory wheels.
Old Oct 5, 2016 | 03:52 AM
  #1653
MS308's Avatar
Default little backlogged
Okay. Not been on for a while. Let's widen my input to "what did I do for last couple months"
- replaced serpentine belt.. wow was that easy! took about 15 minutes.
- then the driver side wheel bearing seals gave out (one after the next) and I had to have a local shop replace wheel bearings.
- for fun I had pipes installed replacing the middle resonator and the last two exiting the back. Kept two of the resonators in. Not too loud, and now the cat purrs at idle and roars when pushed.
- then the fuel pump went out. That pretty much was the end of the fun stuff.
That's it.
Attached Thumbnails What did you do to your X308 Today?-fullsizerender-copy.jpg
Old Oct 10, 2016 | 11:32 PM
  #1654
tsmatsoukas's Avatar
new member, and like MS308, what did I do this month, bought a 1967 420 and the 1999 xj8 from a fellow car club member. left the 420 in the garage....awaiting more attention than I can give it right now. Trailered the xj8 home, been sitting over a year, last fuel added November of 2013 ...no start. changed the fuel pump. starts now. chased asc faults, abs faults. p1467 p1466 o2 codes. Square tires. learned a ton on this forum ..thank you, thank you, thank you. Ordered top front shock plates, and lower rear shock bushes, o2 sensors top and bottom - left and right, took the car for a wheel balance... they refused to touch 2004 date coded "dry-rotted" Michelins. Put a new set of Goodyears on her. topped off the A/C, cleaned the interior, put leather treatment on seats and door cards, trying to decide if I have a cabin air filter??? Found the PO had left the plastic cover on the wiper blade... wondering how to get the scratches out of the windscreen??? Can't get the drivers pass door to lock or unlock with the remote????
Old Oct 11, 2016 | 05:57 AM
  #1655
ericjansen's Avatar
Welcome on the forum.
Seems you did your homework, and tackled quite some issues, great!
I presume you got a new battery too? If not, that might very well be the reason for the codes.
Start with a new battery and an hard-reset, and it might also solve the passenger door issue, although that might be the control box as well.
You will need to do some elimination work there.
Your car does not have an cabin filter.
I have plenty of scratches in our SLK front window, and never really managed a solution.
In spite of some YouTube videos, I don't believe they can be polished out.
Waxing the window helps temporarily, as does applying a petrol based scratch remover, however, it is all temporary.
There is a professional way to remove them by basically removing a very thin layer of your window, but I have no idea of the pro's and con's.
Old Oct 18, 2016 | 04:57 PM
  #1656
booyaford's Avatar
clay bar done in preparation for waxing = dodo juice purple haze....boom
Old Oct 18, 2016 | 06:28 PM
  #1657
CharlzO's Avatar
Clayed mine Sunday, in the middle of wash and wax. It rained 6 hours later, as it always seems to.
Attached Thumbnails What did you do to your X308 Today?-14682193_10154514693307177_2150722991009504389_o.jpg   What did you do to your X308 Today?-14682110_10154514693012177_8933430455753323136_o.jpg
Old Oct 19, 2016 | 05:52 AM
  #1658
Daim's Avatar
I'm just driving it and getting really great mileage out of him...
Reichweite is German for range. In KM that is 704 km range... Okay, I am tricking it, as I only use petrol on cold starts. Rest of the time I use gas (careful! My gas is real gas, not gasoline!). Real bargain banger.
Just the cold start problem needs to be solved. Still won't run well on initial start up. When driven for about 1000 m (0.75 miles) all is fine again. In the same period you can't let off of the gaspedal as the engine will cause a bang in the car's drive...
Old Oct 19, 2016 | 05:24 PM
  #1659
booyaford's Avatar
Default what i nearly done too x308 today
home from work had a spike of energy ah i thought wax ON oh no rained OFF been pleasant all day also.
so i gave it a kiss instead.
Old Oct 20, 2016 | 03:07 AM
  #1660
Stu 1986's Avatar
Originally Posted by Daim
Reichweite is German for range. In KM that is 704 km range... .
Don't the gauges look strange with just the KM/H markings on? I'm so used to seeing them as MPH with the KMs marked on the inside. I wonder why they styled the KM Gauges with little "Teardrop" shapes for the increments and not the MPH?
Glad you're enjoying it, I can speak a bit of German I learnt at school. I'm tempted to go to night school or something to learn more, I was quite good at German but the colleges I attended didn't offer German language courses.
As for me, I've done nothing with my 308 the last 4 days because it's still at the body shop. However I did give my mats a bloody good scrub with hot water. I did it in the bath using the shower to rise the soap off, obviously I wasn't in the bath too! :P
