where can I get my supercharger rebuilt?
for $1100 I can get it rebuilt and ported for an extra 25 but wait a month for it. Any cheaper or sooner, $1100 isnt that bad esp considering porting the blower which then I will do a 2.5 pulley on it as well. Anyone have the same setup? Curious what it would do in 1/4 with say, Ported blower, 2.5 pulley and full exhaust, mid-high 12's? Its an extra 75hp
not a chance....
PSE do a rebuild for something like $800.
Jaguar - PSE Superchargers - Your source for remanufactured original equipment superchargers
You can also buy a brand new one for around £650 from Jaguar, I don't see any benefits from porting an Eaton, just more noise - In fact it can lead to loss of power, see the Kenne Bell info here...
SC Tech Info
SC Tech Info
not a chance....
SC Tech Info
SC Tech Info
Your best bet on the blower is to buy the Gen V from JgaXkr and add a 3lb upper. His will be cheaper/faster/better. It will take 20 minutes with a small grinder to get the GenV to fit, and lots more time to get the smaller pulley to fit, or I suggest you pay JgaXKR to mount the smaller pulley before he sends it to you. His has low miles and I'm sure he will give you a better price than the $1100.
Do you know what your car is running 1/4 mile now as a baseline and have you done a before dyno?
2.5-3lb like this one http://www.ebay.com/itm/150703474192...ht_2787wt_1163
Make sure it is steel, not aluminum for the upper for better belt grip, lower pulley material doesn't matter so much.
