Where I can buy front strut mount bushings?
Old Aug 8, 2024 | 09:18 PM
Silverjag0's Avatar
Default Where I can buy front strut mount bushings?
Hi I replaced my fuel pump lately and unfortunately I'm seeing the upper Mounts bushings cracked
I don't want to replace Mount itself I tried to find the bushings and found Welsh discontinued the bushings
Any idea where can buy these upper bushings?
Old Aug 9, 2024 | 10:18 AM
Parker 7's Avatar
Can you find it in here and which item #
I have the earlier but close X300 with no ride leveling struts
Search Genuine Steering And Suspension Parts For Jaguar Xj 1998 - 2003 (from 812317 To F59525) (x308) Classic | Jaguar Land Rover Classic Parts
Old Aug 9, 2024 | 11:58 AM
Silverjag0's Avatar
X300 front strut mount bushing can fit x308 ?
Old Aug 9, 2024 | 12:11 PM
Parker 7's Avatar
The suspension is very much the same but the parts are different
Don't order from a X300 reference part list
The top of the front strut connection to the chassis ( shock tower ) is different
X300 has no shock tower and is a basic top of strut shaft with rubber isolators ( donuts ) on both sides of the sheet metal / chassis , the isolators defiantly flatten out and get loose on the X300
Ride leveling as this top build up is different and bulky ?
Old Aug 9, 2024 | 12:29 PM
Silverjag0's Avatar
The link you sent show complete upper Mount can see bushing selling separately
Old Aug 9, 2024 | 12:37 PM
Parker 7's Avatar
Link that parts page you have
Old Aug 9, 2024 | 02:24 PM
Jhartz's Avatar
Rock Auto or NOMO in the US have affordable upper shock mounts with new bushings. Once upon a time Parts Geek sold separate bushings which required a press or BFH to build. Lots of threads, do some searching (Jaguar upper shockmounts).
What would be useful is to know what model you have a where you live . . .
Old Aug 9, 2024 | 02:57 PM
Silverjag0's Avatar
As you said once upon time
I will meyle mounts better than uro parts
Old Aug 9, 2024 | 03:02 PM
Parker 7's Avatar
Do you have a pic of your top mount to know what you have ?
Straight strut or air suspension ride leveling with air hoses to the top mount area ?
Old Aug 9, 2024 | 03:04 PM
Silverjag0's Avatar
I have straight struts no air suspension, do you have the bushings parts number I can't find it
Old Aug 9, 2024 | 04:56 PM
Jhartz's Avatar
Try the SNG Barretts Catalog for part number
Old Aug 9, 2024 | 04:57 PM
Parker 7's Avatar
The X308 struts parts list seems to be incomplete not showing the air suspension version
But this may be your straight version hidden in the earlier website link.................
As the cupped saddle with isolators already attached item # 8
Right / MNC2169AF
Left / MNC2168AF
They have both the left and right part # s mixed up in their record
Search Genuine Road Spring And Damper-front Parts For Jaguar Xj 1998 - 2003 (from 812317 To F59525) (x308) Classic | Jaguar Land Rover Classic Parts
Old Aug 9, 2024 | 07:23 PM
Parker 7's Avatar
With the cost you can look into pouring your own as the 2 part material rated X is available on E - bay and such , easy to mold
The material is 2 part poly on this site's diagram that only sells already cast parts
Maybe yours
Old Aug 9, 2024 | 07:37 PM
Parker 7's Avatar
Nope on your part per website
Jaguar XJ8, XJR, XJ Sport - X308 (1997-2003)1994 to 2002) Replacement Suspension Bushings (powerflexusa.com)
But you can contact them
Contact Us | PowerflexUSA
Old Aug 9, 2024 | 08:10 PM
Silverjag0's Avatar
Meyle better choice will buy that one thanks for helping
Old Aug 10, 2024 | 11:05 AM
motorcarman's Avatar
I have tried both Meyle and URO. They both cracked and failed within a year or two.
They are easy to change and cheap to buy so not bad if you keep a spare pair.
I finally got a set of ENERGY Suspension 'SHOCK BUSHING SET' 9.8145G from Amazon or eBay.
I pressed the mounts apart to fit new poly bushes.(too thick as they are but good diameter)
I have a lathe so I mounted one on the spacer tube without the washer. I chucked it up and split the bush in half.
It was a little too thin so I placed a thick flat washer between the original mount washer and the poly bush on both sides.
Put it in the shop press and squeezed it back together. Replicated it for the other side and installed them.
Been on one of my X308 sedans for almost a year and no sign of deterioration.
No harsh noises so I am going to call it good.
Old Aug 10, 2024 | 12:19 PM
Addicted2boost's Avatar
CBC225455
Rear, topmost shock bushing for an XJ40. Need 4 to rebuild a front set.
These bushings are getting quite expensive but, they look and feel just like the original X308 front upper shock mounts once you rebuild your oem Jaguar mounts.
Old Aug 10, 2024 | 02:02 PM
Silverjag0's Avatar
Thank you motorman for the help will buy that bushings I didn't want to replace the mounts itself it looks new only the rubber bushings gone
Old Aug 10, 2024 | 02:03 PM
Silverjag0's Avatar
Originally Posted by Addicted2boost
CBC225455
Thank you
Old Aug 11, 2024 | 05:43 AM
Parker 7's Avatar
" I have tried both Meyle and URO. They both cracked and failed within a year or two. "
Motorcarman ( Bob ) , that is where your level of experience comes in and apricated in getting him along
Amazon.com: Energy Suspension 9.8145G Shock Bushing Set : Automotive Amazon.com: Energy Suspension 9.8145G Shock Bushing Set : Automotive
