Where is the speaker for the interor chimes?
Old Sep 18, 2012 | 10:13 PM
jaguars4r's Avatar
Default Where is the speaker for the interor chimes?
Where is the speaker that control the interior chimes... turn signals, door open.... etc?
Old Sep 18, 2012 | 11:24 PM
Ipc838's Avatar
That would be under the steering column
on the right hand-side, behind the perforated
section.
Mine isn't working, and despite my being a
teenager, my back hurts too much to
get under there right now. There are a few
torx head screws holding the panel in place.
Mine worked on the last XJ, not on the XJR.
I have become acutely aware of whether
my signals are on or off.
Old Sep 18, 2012 | 11:33 PM
jaguars4r's Avatar
yea, I have the same problem, it worked a few times and that was it
Old Sep 29, 2012 | 04:38 PM
Ipc838's Avatar
Any progress? I'm thinking I'll go out to the parking
lot and give it a go in a minute, see if I can just find
an unplugged connector, and an easy fix.
I hope my Torx head is the same size.
Old Sep 29, 2012 | 05:43 PM
Ipc838's Avatar
https://www.jaguarforums.com/forum/x...-signal-64713/
Old Sep 30, 2012 | 11:13 AM
jaguars4r's Avatar
I still cant find the little speaker, any pics?
Old Sep 30, 2012 | 04:45 PM
Ipc838's Avatar
Follow the instructions in post #44. Pull the
white plastic pins carefully.
I was under there, and found nothing wrong.
speaker isn't blown, and the connectors are
all plugged in. I also checked damn near every fuse in
the car and none were blown.
I am stumped.
The sound is purported to come from the body
processor module. I believe you have to take the
glovebox out in order to look at it.
Old Oct 3, 2012 | 01:52 PM
Ipc838's Avatar
Anyone else know something?
Presence
Mar 13, 2016 02:21 PM
magmedia
Oct 8, 2015 03:28 PM
Rocky15
Sep 28, 2015 04:59 PM
Fletch44
Sep 28, 2015 02:21 PM
pino
Sep 26, 2015 08:05 PM
