why is my starter draining my battery, or is it?
Old Aug 2, 2010 | 09:02 PM
xjrwithproblems's Avatar
Default why is my starter draining my battery, or is it?
Well, my battery has been heavily draining recently. About a full volt in about 30 minutes. i went to start it today and it wouldn't turn over but i checked the voltage and it read 13.21v. I would assume that this should easily turn the motor over, right? I plug my battery to my trickle charger for about an hour to get it up to 14.5v, and then observe with the voltometer as it drops .01v per second. I remove the starter wires at the B+ bulkhead and continue to observe the voltometer, it stopped draining. SO, why is my starter draining power? is it a bad starter. bad wiring somewhere.
Old Aug 2, 2010 | 10:01 PM
test point's Avatar
That really doesn't sound like a starter but something is draining the battery. Perhaps an alternator diode? Where exactly are you disconnecting the starter?
Old Aug 2, 2010 | 10:53 PM
i disconnected the starter from under the hood on the passenger side where the two wires are connected through a bulkhead under the engine storage compartment. If it is in fact my starter that is draining power, i think i may just fab up a relay to where power is only available when the ignition is activated.
Old Aug 3, 2010 | 05:04 AM
test point's Avatar
Here is the electrical schematic for the battery/starter system. There is already a relay for the starter solenoid and I don't really think you want to want to install a relay capable of handling the starter current.
Still doesn't sound like the starter/solenoid.
File Type: pdf
Old Aug 6, 2010 | 12:20 AM
hey test point. You were right, it wasn't my starter, it was my bpm, wasn't grounding properly. Got it all sorted out. thanks for the diagram.
Old Aug 6, 2010 | 06:50 PM
QuadManiac's Avatar
What is the BPM, please?
Old Aug 6, 2010 | 07:04 PM
test point's Avatar
Body Processor Module
aholbro1
Dec 29, 2024 06:46 PM
Roger Geirnaert
Oct 12, 2015 01:01 PM
Jahnese Alston
US Northeast
Sep 20, 2015 02:22 PM
Charlene n John
Sep 14, 2015 10:08 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
