Which windscreen wiper do you have?
Old May 23, 2023 | 10:33 AM
seafrostsi's Avatar
Default Which windscreen wiper do you have?
I tried to fit a Bosch Super Plus, but the nozzle prevents it sitting properly and so it sticks up too much at the other end, and the rubber doesn't make contact with the glass at the other end! There is more space for the nozzle on my existing one.
Has anyone else had this problem and what wiper blade do you have?
Old May 23, 2023 | 12:50 PM
aquifer's Avatar
I use Bosch Icon wipers on all my vehicles. It doesn't interfere with the nozzle on the Jag. Edited to add: the Icon does stick up slightly from the corner of the glass in the lowest position on the Jaguar, but isn't a problem in my opinion.
Old May 23, 2023 | 01:13 PM
Vauxi's Avatar
I use bosch AR series blade. Glass is so curvy at the lower corners so the blade won't wipe from there. That doesn't matter at all as it starts to wipe like 5cm up from the rest position. Does not hit the jets etc.
Old May 23, 2023 | 01:31 PM
seafrostsi's Avatar
I don't mind the very end of the wiper not touching the glass, but with this Bosch Super, half of the rubber isn't touching!
Old May 23, 2023 | 03:00 PM
ixfn's Avatar
I use an OE XK8 blade, it gives you the little spoiler on it. The blade end never seems to contact fully when parked regardless of the brand in my experience (40/300/308). I didn't like the look of the arm mounted washer nozzle so I used X300 sprayers and removed the arm mounted one.
Old May 23, 2023 | 03:45 PM
Jhartz's Avatar
Me too, Bosch Icon: clean wipe. I have gotten use to the higher profile.
Old May 23, 2023 | 05:55 PM
Ken Cantor's Avatar
Every time I see one of these threads it makes me wonder why buying a refill wiper element without having to replace the whole blade isn't as common as it used to be...
Old May 24, 2023 | 06:54 AM
Hooli's Avatar
I've not seen them for a while but I do sometimes use the rubber off the replacement to do exactly that as the old one worked/fitted better.
Old May 24, 2023 | 08:25 AM
mayhem's Avatar
Tried a beam wiper and was disappointed that it didn't curve enough to get the lower corners of the windscreen. I switched to plain old $10 conventional Trico blade and its been great. Wipes every bit, its silent and doesn't seem to lift at all at highway speeds.
Old May 24, 2023 | 09:16 AM
Probably many don't know they are available from JLR and aftermarket Jaguar parts specialists. P/N GNB8961AA
Old May 24, 2023 | 10:13 AM
scottjh9's Avatar
PIAA makes a nice silicone wiper. Google piaa wiper blades. They have a nice website
Old Jun 1, 2023 | 11:25 AM
seafrostsi's Avatar
I took the jet off the arm. Could it be I put it back slightly too far up? But there did seem to be 4 small indents in the arm which it seemed to fit in nicely.
I had a look a different Jag today and his jet seems to be about a cm further up than mine and he had a traditional wiper sitting just fine on the glass. Has anyone else got these 4 little indents in their arm?
Some other blokes Jag: jet seems to be further up than mine.
Is my jet too far along?
Old Jun 1, 2023 | 10:21 PM
Probesport's Avatar
I ordered a pair or blades from ebay UK that has integrated sprayers, works well, better spray pattern.
https://www.ebay.com/itm/172770310235
seafrostsi
May 3, 2023 01:19 PM
deepblue
Nov 6, 2022 04:06 AM
Gomesjan
Oct 21, 2022 09:45 PM
mdcliff
Nov 18, 2019 05:21 PM
police666
Oct 3, 2012 09:16 AM
