Wiper turning on when lights and fog lights on HELP
Old Jan 29, 2014 | 05:18 PM
J.Bo's Avatar
Unhappy Wiper turning on when lights and fog lights on HELP
When I turn on the lights the wiper starts to move up the windshield. Also when I turn on the fog lights the wiper turns on and begins to operate very slowly. When the lights are off there is no movement from the wiper unless I turn it on.
Has anyone ever seen such a problem. Help someone please.
Old Jan 29, 2014 | 05:20 PM
J.Bo's Avatar
I've tried the hard reset. That didn't work. So know I did another hard rest and then I unhooked both battery cables and have my trickle charger bringing the battery up to full power. Maybe this will work or not. Any other suggestions?
Old Jan 29, 2014 | 06:04 PM
avt007's Avatar
So far the only common part is the body processor module. I'm having a look at the wiring diagrams, I'll let you know if I find anything.
Old Jan 29, 2014 | 06:21 PM
avt007's Avatar
OK, I think I may have it. The wiper circuit shares a ground stud with the headlight circuit.
The lug number is LS18, and it lives in the left front corner under the hood. If that ground is poor, what happens is the headlights are trying to find a ground through the wiper motor.
Check out these pictures.
http://i336.photobucket.com/albums/n...ps7b13044c.jpg
http://i336.photobucket.com/albums/n...ps56c4a260.jpg
http://i336.photobucket.com/albums/n...ps3bffe050.jpg
With the car turned off, remove and clean up the grounds with steel wool or sandpaper. Let me know if this helps.
Old Jan 29, 2014 | 07:28 PM
J.Bo's Avatar
Thanks. I will let you know.
Come to think about it when I changed the abs control module I disconnected a couple of ground screws right in that area. That just my be my problem. I will update you tomorrow.
Old Jan 30, 2014 | 07:34 AM
J.Bo's Avatar
I went out and cleaned both ground studs on the left side of radiator by the two relays and the wiper still comes on with the lights. Could this be motor related or relays? Where is a good source for relays?
Old Jan 30, 2014 | 01:13 PM
avt007's Avatar
That doesn't make sense. Did the problem start when you did the ABS module?
Did you make sure the body had a clean unpainted area for the lugs to contact?
I'd suggest a couple things- check those out again, and maybe even hook a wire or jumper cable from there to the shock tower bolts.
Could the wires themselves have been damaged, perhaps kinked?
Also try cleaning up the same grounds on the right hand side.
Old Jan 30, 2014 | 01:27 PM
J.Bo's Avatar
I didn't notice the problem when I did the abs module. My wife usually drives the car and she never mentioned anything. We just got the car back from the dealer for a fuel pump replacement and they found the issue in the multi-point check. The service advisor said it could be the body control module because that is the only thing that is shared with the two components. But he is not for sure until they look at it. I'm not going the dealer route and I hope I can fix this on my own with help from fellow members here.
You don't think the abs module has something to do with this problem?
I will give it a try later today after work or over the weekend. I will keep you informed and thanks for your help.
Old Jan 30, 2014 | 01:31 PM
avt007's Avatar
I would keep looking at the grounds in that area. I see there are some underneath the shock tower. Also there should be some around the module. I would not spend money on a body processor, that probably is not your problem, and it is very expensive.
Keep picking away at it, and I'm sure you'll find it.
Old Jan 31, 2014 | 02:05 PM
J.Bo's Avatar
I took the start/stop relay off and the wiper didn't move when the light where on. Of course the wiper didn't work, so I swapped sides with the other relay and as soon as I put the start/stop relay in the wiper started back moving. I now relays are cheap so could it be the start/stop relay causing this problem?
Old Jan 31, 2014 | 04:13 PM
avt007's Avatar
No, I don't think so. I think the ground for the start stop relay is bad, and since it shares the ground with the lights, you are getting power to the wiper through the relay.
[IMG][/IMG]
Chase after the grounds, and trying using jumper cables like I said to ensure those wires are truly grounded.
Attached Thumbnails Wiper turning on when lights and fog lights on HELP-wiper_zps3bffe050.jpg
Old Jan 31, 2014 | 04:16 PM
avt007's Avatar
Here's some shots of the grounds on my XJR.
The left side in the the first 3 shots:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
And the right side:
[IMG][/IMG]
Attached Thumbnails Wiper turning on when lights and fog lights on HELP-c805b550-90b3-4f0f-be0f-2d4c8176eea1_zpsoak5zu4c.jpg   Wiper turning on when lights and fog lights on HELP-feb37cef-e254-4288-853a-b233c824e31f_zpsdaabfgk2.jpg   Wiper turning on when lights and fog lights on HELP-3a635cd9-475d-4fdf-86b2-17a308425e8a_zpsseuyyiqg.jpg   Wiper turning on when lights and fog lights on HELP-a5974cb6-6e6d-40c3-a8c0-89896d89fe16_zpss3nfxip1.jpg
Old Feb 1, 2014 | 12:23 PM
J.Bo's Avatar
I found the ground. I had forgot to hook up on and it was hiding under the abs module. I hooked it up and all is well. Thank you for pointing me in the right direction. Your help was appreciated.
Old Feb 1, 2014 | 02:03 PM
avt007's Avatar
Good work!
Jpav27
Jul 31, 2022 06:43 AM
redrover41
23
Sep 25, 2015 01:33 PM
gene1
Sep 3, 2015 05:58 PM
King Charles
Sep 3, 2015 12:40 AM
XJsc-guy
Sep 2, 2015 11:43 AM
