Wires to one injector gettting very hot, intermittent
Old Jan 14, 2015 | 11:17 AM
Mark SF's Avatar
Default Wires to one injector gettting very hot, intermittent
Last week coming off the freeway and stopping at lights, I could smell burning insulation. Today I found the cause. On the two wires to one of the fuel injectors (front on right bank), the insulation is partly melted.
I ran the engine for a while, and they didn't get warm. Also checked when I got to work this morning.
So clearly the problem is intermittent. What could it be?
Old Jan 14, 2015 | 05:14 PM
sparkenzap's Avatar
Mark:
Is it one or both wires?
Old Jan 14, 2015 | 06:32 PM
Mark SF's Avatar
Both wires, equally affected.
Old Jan 14, 2015 | 08:53 PM
motorcarman's Avatar
You might try and check the injector resistance and then compare to another 'known-good'.
A low resistance will draw more currant and melt the wires.
A big enough draw will fry the output circuit in the ECM!!!!!!!!!
A replacement injector might be required.
bob gauff
Old Jan 14, 2015 | 09:24 PM
Mark SF's Avatar
Thanks, I suspected as much. How easy are they to change?
Old Jan 14, 2015 | 09:36 PM
sparkenzap's Avatar
SO that means the problem is not a short to ground inside the injector. As bob mentioned, testing the injector with an ohmmeter whiole wiggling it a little would be the next step.
mrplow58
Jan 21, 2024 05:53 AM
Rivguy
Nov 13, 2022 02:55 AM
ogorir
Jan 18, 2016 10:09 PM
Bcrary3
Sep 11, 2015 10:36 AM
jaguarbill
Sep 5, 2015 11:43 AM
