wrong part fitted XJR my 1999
Old Jun 5, 2016 | 02:24 AM
dc4prez's Avatar
Default wrong part fitted XJR my 1999
hello all of you jaguar specialists
I finally finished my engine rebuild, taken 2 years all up.
Plugged in battery, put key in and then the codes started -
Engine - trans - suspension PLUS - wrong part fitted -
I haven't put the scanner on it yet, but I could not have even imagined a code telling you that you'd fitted a wrong part. I sort of imagine it is referring to the ECU It has been 2 years since the battery was hooked up, I'm thinking the little back up battery in the ECU is flat.
Has anyone seen this before or any good ideas - please would be a good word about now
Cheers DC
Old Jun 5, 2016 | 04:17 AM
XJR-99's Avatar
Cheers DC
https://www.jaguarforums.com/forum/x...estions-66511/
https://www.jaguarforums.com/forum/x...-4-0-a-156897/
Old Jun 22, 2016 | 06:20 AM
dc4prez's Avatar
Thanks for the advice - got to the bottom of problem - Inertia switch had tripped -
Old Jul 2, 2016 | 08:41 PM
dc4prez's Avatar
Thanks 99 next problem was broken wire in rotating switch on top of gear selector - threw the plug away, soldered the wires directly to the circuit board, then filled it up with epoxy
