X308 BPM Removal
Old May 14, 2014 | 04:41 PM
soprecious's Avatar
Default X308 BPM Removal
Help. How is the best way of removing Body Control Module in my 1998 Jaguar XJ8? Any help would be appreciated. Thank you.
Old May 14, 2014 | 05:15 PM
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to X308 forum. The Advice / Feedback is for posts about the forum and not for technical questions.
Members here with the same model will be able to help.
Old May 15, 2014 | 12:00 AM
plums's Avatar
glove box out, then four fasteners and assorted connectors.
highly doubtful that the BCM needs to come out as they are not usually a source of trouble.
Old May 15, 2014 | 12:10 PM
soprecious's Avatar
]It is the BPM[. We were able to get to it (removed glove box) and plug in the new (used) one. Everything lit up like a Christmas Tree. What we need to know how is the best way to remove the old one and replace. Last I read someone said remove the three bolts that is holding it and push it up and out. That is not working. We are blocked each way we go.
Old May 15, 2014 | 12:45 PM
plums's Avatar
nuts not bolts, so you probably have to lift it clear of the studs
Old May 15, 2014 | 01:32 PM
soprecious's Avatar
Default Bpm
Question is - BMP unmounted. What else should be removed or unmounted to get it out of the car?
Old May 16, 2014 | 12:02 PM
soprecious's Avatar
We are just two females wondering if we just slam dunk it down and out? We are beginning to think that whoever designed this car was on some serious drugs! LOL
Old May 17, 2014 | 11:49 AM
plums's Avatar
A *good* picture would be helpful at this point.
I don't remember any difficulty with access and I was up in there with both hands, a soldering gun and wires making modifications to circuitry.
Old May 17, 2014 | 02:50 PM
jimlombardi's Avatar
Plums - Here you go:
Jim Lombardi
Old May 19, 2014 | 12:41 PM
soprecious's Avatar
BPM Removed. Thank you guys.
2001 White XJ8
Feb 25, 2021 05:02 PM
Forcedair1
Feb 19, 2020 01:51 PM
xjrjag
Aug 17, 2019 03:45 AM
vsol
Aug 29, 2018 09:46 PM
al_roethlisberger
Sep 7, 2015 10:53 PM
