X308 plastic cover for spark plug / coils
Old Jun 19, 2021 | 07:02 AM
bfx308's Avatar
Default X308 plastic cover for spark plug / coils
Dear all,
I've recently swapped spark plugs and after removing the screws which hold the plastic cover on top of the coils & spark plugs in place, we noticed some corrosion underneath.
The reason for this corrosion is that one of the 8 screws for the plastic cover of the spark plug compartment are missing, and also that the plastic cover is broken in a certain place.
So here comes my questions:
- Does somebody know the part # of the screws for the spark plug plastic cover?
- Is there a replacement part for the spark plug plastic cover available?
Thank you very much,
bf
Picture of corrosion:
Picture of plastic cover for spark plugs:
Old Jun 19, 2021 | 07:04 AM
bfx308's Avatar
BTW on the second picture of the plastic cover you can see the broken screw holder on the top left of the picture. The plastic around the metal part has been broken off, which is why I would like to replace the plastic cover in order to re-seal the spark plug compartment.
Old Jun 19, 2021 | 08:03 AM
Highhorse's Avatar
This place is just over in France...https://www.jagpieces.com/6-vis-hexa...2c-c2x26926305
As for the cover, there are plenty about the internet, just type in that part #... NCA2570CA ...yours end in CB, but when I used that, nothing but motorcycle parts came up on my end.
Old Jun 19, 2021 | 08:23 AM
bfx308's Avatar
That helps a lot - thank you very much! It's always hard to find the right word in English language when you're looking for a car part
Old Jun 19, 2021 | 08:36 AM
bfx308's Avatar
So it seems the "x308 ignition coil cover" has number:
- AJ84151G at https://www.britishparts.co.uk/class...il-cover-p1408for 80 GBP (but out of stock)
- NCA2570CA at https://www.certstoreu.com/index.php...ucts_id=137835 for 122 CAD or https://www.ebay.com/p/1911247222?iid=233979813981 incl. screws for 57 USD
- NCA2570CB at https://www.ebay.de/itm/Deckel-Abdec...-/203193380212 for 39 EUR
And the six hexagonal screws for the x308 ignition coil cover have number JFS10512C and can be ordered at https://www.jagpieces.com/6-vis-hexa...2c-c2x26926304 for 6 EUR.
Maybe I should go with the
NCA2570CB because that's the exact part # written on the one I am trying to replace.
Thank you very much!
Old Jun 19, 2021 | 08:49 AM
bfx308's Avatar
In some places the "x308 ignition coil cover" it is also labeled as AJ84151, such as https://www.ebay.de/itm/160982957941
Old Jun 19, 2021 | 08:53 AM
bfx308's Avatar
Number for the screw is JFS10512C and available at https://www.brit-car.co.uk/product.p...0/screw_flange for 2 GBP and at https://parts.jaguarlandroverclassic...ead-screw.html for 2 GBP each.
Old Jun 23, 2021 | 07:13 AM
bfx308's Avatar
Today the used NCA2570CB part arrived from ebay for 39 EUR and I installed it. Worked like a charm. Happy to have resolved this small issue - thanks for all your help!
wforslund3
Feb 21, 2020 11:57 AM
Leaper_Man
Dec 8, 2014 08:33 PM
Vee
Nov 5, 2010 07:07 PM
Mcavty
Sep 26, 2010 11:16 AM
hlgeorge
Jan 6, 2009 01:25 PM
