X308 Radiator swap
Old May 4, 2021 | 09:45 AM
timskipper's Avatar
Default X308 Radiator swap
Is it possible to replace the main coolant radiator without taking all the a/c pipes, gearbox cooling etc off?
Old May 4, 2021 | 10:45 AM
Jhartz's Avatar
No comprendo. You have to disconnect some fixtures to remove the radiator, ne? Some, maybe not, all need to be moved aside to provide room . . . what the **** am I missing?
More politely: if you have never done car repairs before, hire somebody . . .
Old May 5, 2021 | 08:23 AM
Elmo1544's Avatar
Default Civility
He asked a straight forward question. You should have stopped with the first sentence. How do you know he is not going to take it to a mechanic and wants to know his options first?
Less politely "What the **** am I missing about the true message being sent by the tone of your reply?
Old May 5, 2021 | 08:26 AM
timskipper's Avatar
Meh don't worry about it. I'm quite comfortable spannering but there is quite often a "trick" to doing stuff that can save a bunch of time/effort. I was wondering if this was one of those situations.
Forums be forums.
Old May 5, 2021 | 11:16 AM
Highhorse's Avatar
A radiator is about as basic as you can get regarding mechanical works. Everything is right in front of you, ..just not the easiest to reach, thus the response by Jim....who's been here quite awhile and a very capable Tech. I mean he only has 15 cars listed in his signature.
The only thing to make it easier would be taking the hood off.
Without fan after tensioner replacement....
Old May 5, 2021 | 02:12 PM
Elmo1544's Avatar
For a step by step how to search
Xjr x308 radiator removal
Old Jun 23, 2021 | 10:56 AM
vincent661983's Avatar
I replaced mine with powerhouse UK intercooler/radiator. it is worth it.
Old Jun 24, 2021 | 02:39 AM
cat_as_trophy's Avatar
Welcome aboard Tim and, equally politely, like [Elmo] I have a similar car to yours, being normally aspirated, though earlier in production. The answer to your very reasonable question is . . . no.
Unlike the XJ6 Series I, II, III and then XJ40, on which you can reposition but not need to disconnect the AC system, for the X300 and your X308, you do need to de-pressurise the AC system, and disconnect the evap, as well as same for transmission heat exchanger lines. I suggest you start by grasping a firm understanding of how the rad is located and thus, how it will be removed (workshop manual in the Stickys, pages 973-979).
Unless you have both skills and gear to de-pressurise the AC, take it to a shop, ask them to do so, undo unions and plug them, pull compressor fuse. You then drive home, do your stuff. When you return to shop, get them to fit new O-rings to unions, connect evap, replace fuse and, as they say in the classics, Bob's yer uncle!
Notice how I gloss over "do your stuff", because there is plenty there to frustrate, especially if whoever was there last, left the hose compression clips in awkward to reach orientations. Ask me how I know! However, you are obviously competent with the spanner twirling, so I wish you well with the outcome.
Cheers,
Bonn
Aug 29, 2020 09:50 PM
Xanzar
May 13, 2020 09:15 PM
Lcgi
Oct 5, 2014 07:01 AM
jeremiahjaguar
May 27, 2012 07:38 PM
Xx_Four_Stroke_xX
Jan 19, 2011 07:51 AM
