XJ8 2002
Old May 15, 2017 | 06:23 PM
leroy1's Avatar
Default XJ8 2002
while driving shut off no power engine fail safe/ gear fault show up\ engine would start no power to switch set for 5 min car started up
Old May 15, 2017 | 06:36 PM
I've moved your post from Jaguar Forums Feedback & Suggestion Centre to X308 forum. This is the place to post technical questions about your model.
Old May 15, 2017 | 06:47 PM
leroy1's Avatar
while taking a ride down the highway my car just shut off all light come on the dash with engine safe mode, gear fault, pull over off to the side of road turn off key try to start Err showed up on temp control no power to starter, wait 5 min every thing cleared off of dash. next day car did the same thing check batter its good cable all good had to sit for about 5 to 8 min before the car would start. have any one had this problem with there xj8 2002
Old May 16, 2017 | 12:46 AM
JagV8's Avatar
Sure sounds like a power fault. You just have not yet found it.
Old May 17, 2017 | 08:18 PM
RDMinor's Avatar
Default A seldom thought of part but it will stop you dead inyour tracks
This is not one that shows on most peoples radar as it seldom happens. I've seen it twice in the last 50 years! Yes half a century...holy cow I'm old !!!
Back in 1967 I was rolling up I4 in Central Florida one night going about 75-80 at night. Wham, everything goes dead...lights, engine, everything with no warning. Rolled to a stop on the side of the road. Started right back up and away I went. Over the next several days it did it a couple more times and with greater frequency. Long story short I happened to be looking at the ammeter the next time it did it and saw it peg big time on the positive. Can you say alternator?? Not a bearing so no noise. A failing diode. Replaced and it never happened again.
Forward about 45 years and I get a call from my daughter that her car has died at a 7/11 about 50 miles from home...short story ..dying alternator.
Go to an Advanced Auto and see if they can run a free battery & alternator output test...if it will start of course<G>
Preacher-Steve
Nov 21, 2016 06:36 PM
winefan94920
Oct 16, 2016 02:52 PM
altownsend
Apr 12, 2007 06:14 PM
altownsend
Mar 22, 2007 02:56 AM
Feb 1, 2007 03:09 PM
