XJ8 Loose Driver seat switch pack
Old Aug 5, 2012 | 01:54 PM
jjane1's Avatar
Default XJ8 Loose Driver seat switch pack
Hi guys, have any of you had luck repairing the loose driver power seat switch pack, seems like 80% of used xj8's have this switch loose and just hanging outside the seat, very annoying, thank you, JJ
Old Aug 5, 2012 | 04:05 PM
RJ237's Avatar
My XK8 was the same. I just put some clear silicone seal around the edge of the switch and wedged in until it set. I can pry it back out if necessary.
RJ_____________________
97 XK8 85K mi
Old Aug 5, 2012 | 04:38 PM
jjane1's Avatar
Thanks I was just wondering what causes, it is a broken switch or something broke inside the seat itself?
Old Aug 5, 2012 | 06:15 PM
RJ237's Avatar
No, it's the latch at the back that breaks when taken apart by someone who doesn't understand how it works. The problem is that it's not easy if you haven't seen how it releases. RJ
Old Aug 5, 2012 | 10:07 PM
pdog2000's Avatar
yes there are 4 tabs on the back of the switch pack...buy one ebay even if it is the wrong color it is easy enough to take apart and switch the parts around...
Old Aug 6, 2012 | 08:28 PM
motorcarman's Avatar
The only way to get a new switch retaining bracket is with a new seat cushion. They come molded into the foam.
You can cut it from the new cushion and glue it into the old cushion if you want.
bob gauff
Old Aug 7, 2012 | 05:09 AM
Distraxi's Avatar
Odds on only 2 of the clips (the top ones) are broken. In which case a couple of self tappers through the switch pack surround and into the seat base plastic will do it. Use black countersunk ones and it pretty much looks like it was meant that way.
Old Aug 7, 2012 | 07:36 PM
jjane1's Avatar
Excellent idea, actually the top right is broken,thanks for the tip,JJ
99xk8guy
Sep 29, 2025 10:51 PM
Jpav27
Jul 31, 2022 06:43 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
laserguy
Sep 3, 2015 02:02 PM
Dallas XK8
Sep 3, 2015 12:17 PM
