XJ8/X308 1997 Front subframe bushings MNC2370AC
Old May 6, 2022 | 02:43 AM
jaguar.x308.1997's Avatar
Default XJ8/X308 1997 Front subframe bushings MNC2370AC
Dropped the subframe, and had ordered the subframe bushings aftermarket(since the originals are not currently available). After pressing out the old genuines ones with a hydraulic press, the new aftermarket ones strangely could fit in just by hand very easily... I am worried that if they will be installed they will rotate out of their angled position.
Anyone has experience in reinstalling new subframe bushings MNC2370AC? Am I right that they should not fit by hand and should fit tight with a press instead?
Im thinking of returning the aftermarket ones and will try to find the originals...
Old May 6, 2022 | 12:24 PM
Addicted2boost's Avatar
You’re right, they should not fit in by hand. A press was definitely needed when I did mine about 4 years ago. They should also be clocked in a certain position prior to pressing in. If you’re unsure of the position, then I’ll go through my old phone to see but, it might take some time.
timedwards
Jun 15, 2024 08:45 AM
Zues
Mar 19, 2018 05:25 PM
Bcrary3
Aug 7, 2015 10:12 AM
David N. Warner
Apr 21, 2015 07:54 AM
chasman
Jan 27, 2015 02:23 AM
