XJR heads - same as N/A 4.0?
Old Apr 20, 2011 | 08:48 AM
Duke Thrust's Avatar
Default XJR heads - same as N/A 4.0?
Guys,
Looks like one of my heads has gone porus and I need to find a replacement, are they the same as the non-supercharged 4.0?
Old Apr 20, 2011 | 09:35 PM
motorcarman's Avatar
Here is some info on determining to compatibility for fitting the cylinder heads.
The Supercharged heads need to have the oil gallery plugged if the heads are from a normally aspirated or drilled out for fitting the SC heads to a NA engine.
bob gauff
File Type: pdf
File Type: pdf
Old Apr 20, 2011 | 11:54 PM
plums's Avatar
bob gauff
Those holes at the rear face of the cylinder head with the "dowty" plugs ... are they under full oil pressure? Looking for an alternate place to fit an additional oil pressure sender.
Forcedair1
Feb 19, 2020 01:51 PM
Dicque
Sep 19, 2015 12:53 PM
Wolfy
Sep 11, 2015 06:27 AM
hoodun
Sep 7, 2015 07:12 PM
Dicque
Sep 4, 2015 12:50 PM
