XJR Relay location
Old May 27, 2010 | 12:57 PM
yeldogt's Avatar
Default XJR Relay location
Can't seem to find the location of the box for the HO2 sensor heater Relay -- In both the Main and the Supplement manuals they list it on the passenger side of the engine compartment -- can't find it.
Any ideas ?? Its in with seven others -- ???
I'm doing some basic stuff to see if I can get to the bottom of the P1647 code
Old May 27, 2010 | 01:19 PM
yeldogt's Avatar
Default Timing Chain and Vin #
I have been reading a lot about the timing chain issue since finding this forum a little while ago.
My 02 XJR has a build date of 09/01 and VIN ending in MF45829 -- some indicate a tensioner change over for the engine of 08/01. But that would only be to the second type of tensioner.
Am I correct that none of these have the metal ones installed?
My car has always had some start up metallic sounds -- The dealer has always indicated that all was normal ??
Old May 27, 2010 | 01:21 PM
yeldogt's Avatar
Sorry, I wanted to put my second post on its own
Old May 27, 2010 | 02:22 PM
test point's Avatar
There is no direct correlation between VIN and engine serial number. Any dealer can look up the engine serial from the VIN. The first engine with metal tensioners was made on August 13, 2001, too close to call on your car. Engine serial number would be 010813hhmm.
Here is the relay layout. The O2 heater appears to be the rear half relay in the firewall extension on the right side. Forgot you couldn't download yet.
File Type: pdf
Old May 30, 2010 | 01:09 PM
ronnie's Avatar
Default jag over heats
I have a 2000 xj8 and it over heated, the fan does not come on when
i start the car, it runs when i shut it off,coolant looks good can it be the relay
Old May 30, 2010 | 01:11 PM
ronnie's Avatar
i have a 2000 xj8 and it over heated, fan does not come on when running comes on after i shut the motor can it be the relay coolant looks goog
Old May 31, 2010 | 09:57 AM
Markus's Avatar
[QUOTE=test point;207682]There is no direct correlation between VIN and engine serial number. Any dealer can look up the engine serial from the VIN. The first engine with metal tensioners was made on August 13, 2001, too close to call on your car. Engine serial number would be 010813hhmm.
The engine number is stamped on the top of the engine, left front, by the thermostat housing - you can read it with a properly aimed penlight without having to disassemble anything. It will tell you the date and time the engine was made, eg engine number 9810210631 was made October 21, 1998 at 6:31AM
Old May 31, 2010 | 01:34 PM
yeldogt's Avatar
Boy --- I just went to look for the number. On my 02 XJR there is so much stuff in the way -- I can not see a thing.
Donzi
Oct 18, 2018 12:26 AM
abonano
25
Sep 25, 2015 10:43 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
leep123
Sep 12, 2015 06:53 PM
tonyforman
Sep 10, 2015 07:23 PM
