XJR slow coolant leak
Old Mar 5, 2016 | 10:55 AM
gabrielbecheanu's Avatar
Default XJR slow coolant leak
Hi
A few days ago afther the engine reach the normal temperature a see from the engine compartment coming steam i stop the car and try to find the source of the steam. One conector on one pipe coming ftom the engine to the heater sistem start to blead at high presure, i make a photo of the connector but i do not find it on the program, can any one help me to identify?
Old Mar 5, 2016 | 11:27 AM
NBCat's Avatar
It is always helpful if you provide MY and other vehicle details when seeking assistance.
Old Mar 5, 2016 | 12:21 PM
2000 xjr vin F15008 row
Old Mar 5, 2016 | 01:53 PM
Highhorse's Avatar
Norma is a company that supplies quick connect/release ends for many companies. You can purchase the end by itself and try replacing it if you want to be frugal. Look on eBay for Norma PA6 GF50. But I will assume you want the whole hose to replace?
Without a larger pic of the area you are speaking of I hope this helps you locate the piece you need?
Old Mar 6, 2016 | 01:27 AM
I found it on the right picture, position 6
Old Mar 7, 2016 | 01:52 AM
Hi
A friend of mine told me that inside this connector it is an O ring and can be repleace.Opel use this type of connector and he fix a lot of them by repleace only the O ring
Best regards
Old Mar 7, 2016 | 10:17 AM
Jhartz's Avatar
That should work provided you don't bugger the fitting or pipe while removing.
Old Mar 18, 2016 | 12:36 PM
Hi
I fix the problem today. Change the thermostat and cut the hose rapid connector. It was impossible to change the o ring, i put the hose direct in to the pipe using a hose clip
Best regards
adenshillito
Apr 17, 2016 02:49 AM
XJeej
Mar 18, 2016 06:06 AM
MrWest
Feb 27, 2016 01:54 PM
Mr rx-7 tt
Feb 21, 2016 11:11 PM
TXE36
Feb 20, 2016 06:56 AM
