XJR Springs
Old Apr 1, 2015 | 11:48 AM
Jagblack's Avatar
Default XJR Springs
Hello guys,
can someone tell me if I could fix "normal" Xj8 springs on xjr suspension damper?
What is the difference between this springs:
- JLM20636
- JLM20424
- JLM20422
- JLM20423
It is very important because I have to buy tomorrow morning two shocks.
Many Thanks,
Jagblack
Old Apr 1, 2015 | 11:58 AM
Mark SF's Avatar
You could do that, it's the setup I had on my XJ8 when I put XJR shock absorbers on it. However, the ride was rather unsettled and I consider the ride better in my XJR. The shocks should match the springs.
Old Apr 1, 2015 | 12:14 PM
Jagblack's Avatar
So both springs have the same size?
Old Apr 1, 2015 | 12:40 PM
Mark SF's Avatar
Is it an XJ8 or XJR?
Old Apr 1, 2015 | 12:43 PM
Jagblack's Avatar
It's an Xjr.
My xjr suspension dampers are fine,
but the xjr springs are broken and so i have to replace them.
It's very difficult to find xjr springs in Poland and so that's why I'm asking.
Old Apr 1, 2015 | 01:58 PM
Mark SF's Avatar
Well, I'm sorry, but based on my experience, I can't recommend putting XJ8 springs on it. Perhaps some other members can suggest an alternative?
Old Apr 1, 2015 | 03:25 PM
Jagblack's Avatar
I would be grateful if somebody could tell me if it's possible or not. That's the most important question.
Old Apr 1, 2015 | 03:29 PM
plums's Avatar
It would probably work, but the results may not be optimal.
In non-US markets, the XJR springs are shorter and stiffer
than the XJ springs.
That implies that the distance between the top and
bottom spring pans on the rear dampers on the XJR
is the same or shorter.
Old Apr 1, 2015 | 03:38 PM
Jagblack's Avatar
In my opinion it isn't a problem if it's not optimal. I need it only for 2 weeks, after that I will fix it with the right ones.
Old Apr 1, 2015 | 03:46 PM
Jagblack's Avatar
One more thing: I will change only the front springs.
The springs on the back are in a good condition.
Old Apr 1, 2015 | 04:18 PM
Jagblack's Avatar
Can anyone else approve if it's possible to change the front springs?
Old Apr 1, 2015 | 04:21 PM
Mark SF's Avatar
It just got even worse. You'll now have front springs softer, and longer, than the rears. Making the front springs softer relative to the rears will reduce understeer / increase oversteer, not a great idea in a powerful, rear wheel drive car. You could be making a deathtrap in the handling department, and when you crash your insurance will be invalid.
Old Apr 1, 2015 | 09:06 PM
Jhartz's Avatar
But, mark, it's in poland. jagblck, visit SNG barrett and buy and install the right part!
Old Apr 2, 2015 | 05:55 AM
Jagblack's Avatar
Which color is on the springs of an xjr?
Forcedair1
Sep 8, 2025 01:57 PM
scooternva
29
Mar 25, 2025 12:45 PM
Don R
Sep 14, 2015 12:34 PM
Ipc838
Sep 13, 2015 03:27 PM
Tar
Sep 6, 2015 11:24 AM
