XJR - White Smoke at Start-up
Old Sep 26, 2009 | 07:32 AM
budsang1's Avatar
intentionally giving yourself exhaust leaks doesn't sound like a good idea though
Old Sep 26, 2009 | 09:10 AM
budsang1's Avatar
sounds great if it works...I don't have any white smoke issues currently
Old Sep 29, 2009 | 10:14 AM
user 2029223's Avatar
Banned
Oli and All,
If drilling holes solved the problem then it was most likely water vapor causing white smoke at start up. However, I seem to recall that a brake fluid leak can cause the same symptom.
It goes like this; brake fluid leaks from around the master cylinder actuating rod and accumulates in the brake vacuum booster. On start up, this fluid is sucked into the engine via the vacuum line and causes "white" smoke. Sometimes the fluid leaks is so small that one doesn't realise how much fluid is being added at regular service intervals by the owner and various service techs.
Hope this helps sombody.
Old Sep 29, 2009 | 11:06 AM
H20boy's Avatar
Oli, thanks for the post, it sounds like it worked for you, and makes sense. I think the XJ has more than one true cause for fluffy clouds on startup. Yours sounds like the easy kind.
Old Oct 3, 2009 | 02:03 PM
stkxjrtech's Avatar
too bad mine wasnt that easy to get rid of the smoke, had to replace head gaskets last weekend on the R. Lucky i have the cam and crank locking tools!!
Old Oct 3, 2009 | 02:42 PM
edo's jag's Avatar
Default transmition output input speed sensors HELP!!!
Hi, I have a 1998 XJ8 and the trany is giving me problems the code that i am getting is P1772 i think I have to replace the transmition output input speed sensors. but I cant find them any where. does anyone knows where i can find them and how much do they cost??
Thanks in advance
GordoCatCar
Jan 2, 2017 01:10 PM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
Tim Goz
Sep 17, 2015 09:11 AM
XCrossWindsX
Sep 5, 2015 10:58 PM
