XJ40 ( XJ81 ) 1986 - 1994
1989 vanderplus
Old Nov 10, 2018 | 10:08 PM
Andrew Lopez's Avatar
Default 1989 vanderplus
I just got this 89 vanderplus it was sitting for 4 years I can’t find where to drain oil and the gas lever I’ve been using trunk emergeny switch I turn the car over but seem like no fuel is going in what should I do fuel pump??and also message curcuit 1 and 2 failure can someone help me?
Old Nov 11, 2018 | 02:16 AM
Robman25's Avatar
Just a point the ‘89 Vandenpla is called an XJ40 which is the previous series of XJ6 so this is the incorrect forum.
Old Nov 11, 2018 | 07:24 PM
Ric in RVA's Avatar
And when you get to the right forum it is Vanden Plas...named after a famous coach builder.
Old Jan 28, 2019 | 09:06 PM
British_Atlantic's Avatar
If I had a dollar for every hillbilly on craigslist selling an x300 or an xj40 that called it a "vanderplus" and said it had a V6, well I probably wouldn't have to look for cars on craigslist.
Old Jan 29, 2019 | 10:01 PM
Don B's Avatar
Hi Andrew,
I have moved your thread from the forum for the X300 to the forum for the XJ40, which is the Jaguar factory project code for your 1989 Vanden Plas. Here you will find knowledgeable owners of similar cars who will be happy to try to help.
You can help us help you by giving us more detail, with each topic separated by a period. A separate paragraph for each issue is even better. I'm not trying to scold you, it's just very difficult to interpret your issues when they are presented with so little detail and in one run-on sentence.
Regarding the oil drain plug, it is on the rear end of the oil pan/sump, part 8 in the diagram below. Don't remove the oil relief valve plug, part 4 in the diagram, which is near the front end of the sump:
Regarding the Circuit 1 and Circuit 2 failures, I can't recall what those mean but they may indicate blown fuses. If you don't have the Driver's Manual (Owner's Manual) to look up the definitions of those messages, used copies are often available on eBay and Amazon.
See the links below for a few resources that will get you started on your journey:
Haynes Jaguar XJ40 Repair Manual (U.K edition missing chapters 7 and 8)
Jag-Lovers XJ40 eBook
Jaguar AJ6 Engine Management System Manual
Jaguar XJ40 Electrical Guide 1988-89
Jaguar Classic Parts (Diagrams and Part Numbers)
Cheers,
Don
Old Jan 30, 2019 | 01:33 AM
Lawrence's Avatar
There isn't a gas cap lever, if the car is centrally unlocked the flap should unlock too.
Larry
Old Jan 30, 2019 | 05:28 PM
Tough crowd - not suprised the OP hasn't been back.
Andrew Lopez
XJ40 ( XJ81 )
Jun 20, 2019 03:10 AM
Andrew Lopez
Nov 12, 2018 04:38 AM
Andrew Lopez
XJ40 ( XJ81 )
Nov 11, 2018 01:52 AM
Audio/Visual Electronics
Jan 24, 2010 09:27 AM
