XJ40 ( XJ81 ) 1986 - 1994
1989 XJ6 battery drain
Old Feb 24, 2018 | 02:18 PM
Marc Majlaton's Avatar
Default 1989 XJ6 battery drain
My 89 xj6 has a battery drain. There is a digital beeping coming from the steering column. I think it does that intermittently during the night. What is that sound for? Is that my drain. I've done an amp draw test and have. .02-.03 amps when everything is off. Please help.....
Old Feb 24, 2018 | 02:28 PM
Welcome to the forum Marc,
I've moved your question from General Tech Help to XJ40 forum. Members here with the same model will be able to help.
Old Feb 26, 2018 | 10:32 PM
Don B's Avatar
Hi Marc,
Welcome to the Jaguar Forums! It's great to have you with us.
My first guess is that the dust cover flap in the ignition key lock barrel is not closing properly when the key is removed, causing the "key in ignition" chime to sound continuously and running down your battery. You can usually free up the flap by applying a little penetrating oil to the key and repeatedly inserting it and turning it until the flap closes reliably.
Cheers,
Don
Old Feb 27, 2018 | 01:16 PM
motorcarman's Avatar
Could also be the 'NOT-IN-PARK' sound if the micro-switch is faulty or lever is out of adjustment.
Old Mar 2, 2018 | 05:46 PM
cat_as_trophy's Avatar
. . . and not withstanding the "spot on" advice from Don & Bob, and with the caveat that your decimals are as intended, then 20-30mA quiescent does not seem outrageous . . . in fact, within factory specs, I think. You might like to review the link in my sig below.
Cheers,
Ken
guanshee
Oct 17, 2016 06:19 AM
Michal
Oct 16, 2016 04:23 PM
Nickie
Oct 13, 2016 11:36 PM
muskox3437
Oct 9, 2016 05:29 PM
Nickie
XJ40 ( XJ81 )
Oct 4, 2016 07:52 PM
