XJ40 ( XJ81 ) 1986 - 1994
1990 xj 40 recalibrate tps/ potentiometer
Old May 3, 2012 | 03:20 PM
reedster's Avatar
Default 1990 xj 40 recalibrate tps/ potentiometer
Anyone know how to recalibrate the throttle potentiometer on my car? I removed and cleaned it in an effort to eliminate it as the source of my limp mode transmission fault.with it out of the car I get resistance readings from 5.5 mv to .50 mv. In the car, it will only go down to 1.25mv because of the throttle stop. Even if I had a new one, I would still have to calibrate it.
Old May 3, 2012 | 08:35 PM
limegreenclown's Avatar
Does the throttle butterfly close all the way? It should measure. .6 volts at idle(I know the haynes says .5 but trust me), the only adjustment I know of is the 2 screws on the bottom of the throttle body that allow you to turn it
for limp home mode check this Jag-lovers' Ebooks
also check this Jag-lovers' Ebooks
Old May 4, 2012 | 01:34 AM
reedster's Avatar
THX... I need to get the haynes manual... I got an online disk that is worthless.
Old Nov 19, 2024 | 07:19 AM
jerry_hoback's Avatar
I am commenting on this ancient thread because I spent so much time trying to find the procedure to adjust the throttle pot. Can this be in the stickies?
Lesbrough
Apr 29, 2018 08:49 AM
Joseph12
US Northeast
Aug 22, 2016 02:22 PM
Willafizz
Jul 19, 2015 04:54 PM
randyb
Jun 24, 2014 11:02 AM
sjdsr
Jan 2, 2008 12:01 PM
