XJ40 ( XJ81 ) 1986 - 1994
1990 XJ (Sovereign) Parasitic drain,,,
Old Aug 4, 2020 | 09:17 AM
bunglebear's Avatar
Default 1990 XJ (Sovereign) Parasitic drain,,,
newbie owner here, 1990 sovereign, and must say im loving her!
Battery drain prob at mo, will deplete overnight so have draw somewhere and about to investigate fuses one by one.
But did notice this alarm type thing fitted to battery clamp, it is diconnected but anyone know what is was? im thinking aftermarket alarm system, which may make the parasite hunt more tricky!
Thanks in advance
Old Aug 4, 2020 | 09:37 AM
Don B's Avatar
Hello bunglebear,
Welcome to the Jaguar Forums! It's great to have you with us!
That does look like an aftermarket alarm and could certainly be related to your parasitic drain. Pulling the fuses one at a time while monitoring current draw will help you isolate the circuit(s) in which the drain is occurring. There are a lot of possibilities.
Please let us know what you find.
Also, please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Old Aug 12, 2020 | 10:26 AM
shtekler's Avatar
Default battery drain
Thanks in advance
I have the Jag XJ6 1990 and I have this switch that disconnect the battery (I will try to add a picture)
Old Aug 13, 2020 | 09:10 AM
motorcarman's Avatar
The 'ATTACK-BELTS' are prone to drain the battery when the system fails.
The motors sometime keep forcing the belt mechanism after the travel end is reached.
The lights in the front headrests sometimes 'stay-on'.
Lots of things to check.
Peter 2700
17
Nov 25, 2020 10:13 AM
marky151
Sep 3, 2016 06:22 AM
GBoucher
39
Sep 30, 2013 03:42 PM
Simprof
General Tech Help
Feb 19, 2011 04:59 PM
Apr 25, 2007 04:47 PM
