XJ40 ( XJ81 ) 1986 - 1994
1990 xj6 VCM
Old Feb 7, 2015 | 06:02 PM
sarmond37's Avatar
Default 1990 xj6 VCM
Hello all. Look for a little help have some fuse issues. When I hit the vcm button on dash it tells me (fuse 1 and 2 pao fail) any help with this would be helpful.
Old Feb 7, 2015 | 06:57 PM
Cambo's Avatar
I've moved your post from the X350 section to the XJ40, that's the model of your car.
Welcome to the forum, when you get a moment stop by our new members area and introduce yourself.
Old Feb 7, 2015 | 09:14 PM
Lawrence's Avatar
"pao" is actually "pad" and means your brake pad low sensor has been exposed - usually signifying your brake pad(s) are worn.
There are 3 fuse boxes, one in each foot well and one in the centre armrest. Fuse messages usually signify a fuse has blown, time to check the fuse boxes.
The numbers (I think!) denote the fuse boxes with the issue (1 2 or 3)
"Fail" message alone means there's something up with the fuelling I think ..this is from memory, maybe someone else will chime in and correct me if I'm off on this!
Larry
Old Feb 8, 2015 | 12:28 PM
sarmond37's Avatar
Larry
Hey Larry just wanted to say Thanks for the info. Very helpful. That explains why my brake light is on. Still working on the fuse issue. Thanks
Steve
Old Feb 8, 2015 | 03:43 PM
motorcarman's Avatar
Fuse 1 is the driver's 'A' pillar box (RHD)
Fuse 2 is the passenger 'A' pillar box (RHD)
Fuse 3 is in the console cubby
bob gauff
baskervillema
Oct 1, 2015 01:59 AM
dansxj6
Sep 28, 2015 08:02 AM
XJRick
Sep 28, 2015 02:12 AM
42Ajd
Sep 26, 2015 07:04 PM
