XJ40 ( XJ81 ) 1986 - 1994
1990 xj6 wont start transmission light
Old Nov 9, 2015 | 11:43 AM
joem725's Avatar
Default 1990 xj6 wont start transmission light
I have a 1990 XJ6 4.0 motor. Car drove great until last week I got in it and the motor would turn over but would not start. Also the transmission light came on, the oil light and the battery light. I charged the battery and even tried to jump it. I checked the interia switch and that didn't work. Also I'm not getting spark. The car drive fine all of a sudden it won't start I don't know if it's in some form of safe mode or something. Any info on how to fix this would be appreciated thank you
Old Nov 9, 2015 | 07:48 PM
Lawrence's Avatar
Hi there Joe,
Well first off I wouldn't be too concerned about the tranny light, oil light and battery lights coming on, they always go out after the car starts so if it won't start it's normal for them to stay lit up.
You say you're not getting spark? That could be caused by the crank position sensor failing. One way to see if the sensor is doing its job is to look at the rev counter when you crank the engine. If the rev counter doesn't move, the crank position sensor is suspect.
So check that first then report back, ok?
Larry
Old Nov 10, 2015 | 06:02 AM
Originally Posted by joem725
I have a 1990 XJ6 4.0 motor. .........
Welcome to the forum joem725,
(I've deleted the identical post you made in XJ6 & XK12 Series I, II & III forum.)
Old Nov 10, 2015 | 03:02 PM
joem725's Avatar
When I crank the car the tach doesn't move at all
Old Nov 10, 2015 | 07:54 PM
Lawrence's Avatar
Thats a classic symptom of a hooped/knackered CPS (crank position sensor) , get a new/used one and you'll be good to go. These things fail without warning.
I THINK your part number is dbc2139, check yourself with your VIN - you can pay a little or a lot for one of these, this place has one for around a hundred bucks and it's a new one ....
JA-DBC2139 - Speed Sensor XJ-40 To VIN 629285 (Mid 1991) LUSEB101
cheers
Larry
Old Nov 10, 2015 | 08:11 PM
joem725's Avatar
Thank you I was really bummed I thought the car was dead and I would have to junk it. I'll look into the sensor thanks
Old Nov 10, 2015 | 08:37 PM
Lawrence's Avatar
hey good luck hunting one down, they are easy to fit, just one bolt holds them on.
If you google "xj40 CPS" you'll see this is a pretty common issue on our cars.
Don't forget to come back and let us know when you get up and running again, ok?
Larry
teacoff
Nov 27, 2022 05:36 PM
garyp
Oct 23, 2015 06:13 AM
xkeots
Oct 18, 2015 08:59 AM
hstovall1
Oct 17, 2015 09:32 AM
BobRoy
Oct 11, 2015 01:32 PM
