XJ40 ( XJ81 ) 1986 - 1994
1992 Jaguar xj6 throttle bog?
Old Aug 24, 2020 | 09:54 AM
MPDano's Avatar
Default 1992 Jaguar xj6 throttle bog?
Hello all,
Picking back up on one of my projects. I replaced the oil/filter, reconditioned injectors, new spark plugs and wires. New shocks and shock bushings all the way around. Fixed all the vacuum lines and mice eaten wires. I get throttle bog. I didn't replace the cap/rotor yet but wondering if this could be the culprit or something else I need to be looking at? Also noticed it doesn't start well cold, I need to hold the gas pedal till it warms up for about a minute.
Thanks in advance,
Leo
Old Aug 24, 2020 | 10:31 AM
Lawrence's Avatar
Try cleaning the intake plumbing hoses, replace the air filter, clean the throttle body and set butterfly to specs. Then clean and decarbonize the idle control valve and valve body and reset the idle valve. That should do it ...oh -and change the cap and rotor too!
Larry
Old Aug 24, 2020 | 10:37 AM
MPDano's Avatar
Larry
Thanks for the reply! Is there a pic online that I shows the location of the icv as well as procedures in resetting?
Old Aug 24, 2020 | 12:38 PM
Lawrence's Avatar
It's on top of the intake manifold about 2/3rds of the way back towards the firewall, has an oval plug about an inch or so and the reset procedure is here:
Jag-lovers' Ebooks Book Index
hth
Larry
Old Aug 24, 2020 | 02:09 PM
MPDano's Avatar
Cleaned the throttle body, replaced the cap and rotor. Air filter is new. Not sure if I broke this hose, but is there a part number or a site to find out? I am assuming the local parts store is not going to carry it.
It attaches to the oil fill tube.
Old Aug 24, 2020 | 06:03 PM
jerry_hoback's Avatar
Id say you have a bit of a vacuum leak there. That hose is available from Barratts or Moss motors. Its not extremely expensive either as i recall, though times have changed....... Definitely check for other leaks too, as that one would mask several others... Good luck!
Old Aug 24, 2020 | 10:46 PM
MPDano's Avatar
Thanks for the referals. Tried those site and very difficult to find parts. I ended up finding it using google. 1988-1992 Jaguar XJ6 Breather Hose MTC
I used black rtv for now to seal it while I wait on the order. I got a new CL, assuming now that I fixed the leak. I drove it around and same bog, really feels like not enough fuel. I replaced the cap and rotor before my test drive. I'm going to replace the fuel filter and re-test drive. Here is a picture of the CL
Old Aug 24, 2020 | 10:52 PM
MPDano's Avatar
Adding this link for fault codes.
AJ6 FAULT CODES AND IDLE SETTING / AJ6 Engineering
Old Aug 24, 2020 | 11:40 PM
Lawrence's Avatar
Yes well as the air temp sensor is at the end of that broken hose and ff16 shows air temp sensor fault, good chance the new hose will fix things.
Larry
Old Aug 25, 2020 | 08:26 AM
MPDano's Avatar
Larry
Hose is now free of leaks though.
Old Aug 25, 2020 | 11:51 AM
Lawrence's Avatar
Well fit the new hose, clear the code and see if it comes back -
Larry
MPDano
Aug 24, 2020 09:51 AM
Dave209
Jun 2, 2020 01:57 AM
Broken_Spanners
Sep 3, 2014 08:14 AM
monbenkey
Feb 13, 2014 01:33 AM
PSU 98
Jun 11, 2009 07:33 PM
