XJ40 ( XJ81 ) 1986 - 1994
1994 4.0 s cooling fan dont turn off
Old Jul 25, 2010 | 02:49 PM
jaguar4litre53's Avatar
Unhappy 1994 4.0 s cooling fan dont turn off
hi everyone have just joined. I have had this car for 2 weeks its my second jag ive had. Cooling fans will not turn off when i switch ignition off,woke up this morning and battery is flat. Any ideas please and thanks in advance.
Old Jul 25, 2010 | 04:55 PM
Cadillac's Avatar
I believe Series IIIs suffered from this culprit you mentioned , fans stuck on .
Sorry ,I can't give you the best idea apart from removing the fan relay each time you stop the engine .
You will prolly end up buying a fan relay ,I hope that's that .
Mine nowadays developed a strange problem , just as I insert the key and even when the engine is dead cold , fans start running on their own along with low coolant light on the dash .
Old Jul 26, 2010 | 04:40 PM
thanks Cadillac am trying to get hold of fan relay DBC11617 seem to be rather scarce but still trying. Hope you have some luck with your problem that is a strange one.
All the best Ted.
Old Jul 27, 2010 | 05:15 AM
Cadillac's Avatar
Thanks , I can give you some addresses
www.britishparts.co.uk (since you're in the UK )
Nalley Jaguar , JPAM (those are our vendors )
www.jagbits.com
www.motorcarsltd.com
I believe you can find the relay you need
or
www.ebay.co.uk
Old Aug 9, 2010 | 12:29 PM
Heimis's Avatar
Hi
My 1994 4.0 S just did the same today: fan won't stop.
I just had the air conditioning refrigerant refilled today, and after/during the refill the problem mysteriously began. This should have nothing to do with the fan, but what can you do
However, now the problem is that I can't locate the fan relay, but have to disconnect the battery to cut the fan power. Haynes tells that the relay should be in the LH front corner, but I can't find it? Does the relay look different from normal relays, or should I look somewhere else?
Old Aug 11, 2010 | 02:53 PM
Default jaguar4litre53
hi there
Its under the front left hand side of the valance (nearside England).
Six screws hold a approx six inch square of splash shield, remove this and look up you will seeit you will probably want a torch. Its about 3 inches long about an inch of it being white the other two inches being green.
Hope this helps. Good luck
Old Aug 16, 2010 | 10:05 PM
Heimis's Avatar
Thanks for the info.
The problem disappeared when I kept the battery disconnected for a few days.
If it comes back, I'll check the relay.
dsnyder586
Dec 29, 2024 07:39 PM
1100me
Jul 24, 2023 06:10 PM
mbergen
Oct 23, 2019 10:26 PM
1100me
Sep 7, 2015 06:26 AM
d a
Sep 3, 2015 02:34 AM
