XJ40 ( XJ81 ) 1986 - 1994
87 XJ40 door handle fix
Old May 28, 2013 | 12:52 AM
creatious's Avatar
Default 87 XJ40 door handle fix
Since owning my 40 and attempting to restore it I have noticed a few tricks to fixing it.
For instance if your door handle is on its way out your handle is more than likely fine. After yanking at mine and shearing off the handle I wssnt very happy. Connecting the outside handle to the inner door lock is a small rod with 2 hooks and a thread. When you pull your jandle the rod lifts the lock and opens the door. Over time this unthreads which makes the rod longer and unable to unlock the door. By twisting it tight you can save a lot of long term hassle. The rods also tend to bend and replacing the rod will almost certainly fix your door.
Dz1rfj
Jul 17, 2018 10:29 AM
GordoCatCar
Jan 2, 2017 01:10 PM
XJsc-guy
Nov 23, 2015 01:56 PM
Dz1rfj
Sep 16, 2015 03:44 PM
hoodun
Sep 7, 2015 07:02 PM
