XJ40 ( XJ81 ) 1986 - 1994
ABS pump not letting fluid to one brake.
Old Mar 27, 2025 | 11:03 AM
SimonV #'s Avatar
Default ABS pump not letting fluid to one brake.
Hi all I'm looking for some advice regarding a 1990 Jaguar XJ6 2.9 . The abs pump is not letting fluid to the front near side brake calliper , resulting in it pulling hard to one side braking . The caliper as been changed as it was in a poor state . But struggling one in finding a replacement online and 2 , somebody who is prepared to try and repair/refurbish. Any help or advice would be appreciated 🙏. The car as low mileage for its age [28k] so assuming a valve may be stuck possibly ?? Is there anything else I could do that could possibly solve the problem? Regrds SimonV#
Old Mar 27, 2025 | 06:01 PM
Bill Mac's Avatar
Hi Simon
You are asking this question in the wrong part of this forum.
The X300 runs from 1994 to 1997
Your 1990 Jag is an XJ40
I suggest you ask that question in that forum.
Old Mar 27, 2025 | 06:18 PM
Don B's Avatar
Hi SimonV#,
Welcome to the Jaguar Forums. It's great to have you with us!
The first question that comes to mind is this: in addition to replacing the front near side caliper, did you also replace the flexible brake hose? A common problem is that when the caliper corrodes and seizes internally, the hose also corrodes internally, leading to the collapse of the steel reinforcement braid inside the rubber hose.
Another thing you can check for is corrosion or kinking of the brake pipe between the ABS modulator and the flexible hose.
Failure of the ABS modulator is not impossible, but is probably not as likely as a problem with the hose or pipe.
Cheers,
Don
Old Mar 28, 2025 | 08:53 AM
Bill Mac's Avatar
I agree with Don.
It is most likely a brake hose causing the problem.
Your car is 35 years old and brake hoses have a definite life. They develop arteriosclerosis.
They fail inwards blocking the brake fluid.
I recently had a hose blockage failure in my S3 XJ6 only about 3 years older than your car and ended up replacing all 3 of my flexible brake hoses.
Tarapoochy
Jul 30, 2024 02:40 PM
Darrol2004
Jul 7, 2023 03:57 AM
Gophat
Sep 17, 2022 03:05 PM
italcarnut
Dec 26, 2019 07:45 AM
mbalce
Oct 29, 2009 11:34 PM
