XJ40 ( XJ81 ) 1986 - 1994
Air bag and abs light flashing....
Old Nov 8, 2014 | 10:39 PM
Ginja ninja's Avatar
Default Air bag and abs light flashing....
hi, ive got my 94 xj6 sport and lately ive had my air bag light and abs light start to flash. any help on what is causing this??? any help will be much appreciated!!!
Old Nov 9, 2014 | 05:56 AM
Cambo's Avatar
Welcome to the forum.
Afraid I can't help much with the ABS & airbag fault lights, but I've moved your post from the XJ220 section to the XJ40 section, this would be the right place for your car.
When you get a moment stop by our new members area and introduce yourself.
Old Nov 9, 2014 | 02:48 PM
carelm's Avatar
I'm not sure about the airbag light, but you may try to clean the ABS sensors from each wheel. As I recall it takes a 6 mm wrench and some cleaner. You will have to drive the car a bit to see if it helps. You may want to test the battery as it may trigger some warning lights.
Old Nov 9, 2014 | 11:50 PM
haha thanks cambo351! and carelm ill try it and let you know how it goes Thanks
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
OkieTim
Sep 2, 2015 12:48 PM
innzane
Sep 2, 2015 10:08 AM
