XJ40 ( XJ81 ) 1986 - 1994
Air Intake
Old Jun 10, 2010 | 05:47 PM
estunum's Avatar
Default Air Intake
I recently purchased this air intake system for my car. When installing it, I noticed the directions stated to be sure to remove a hose from the bottom of the air filter box. Then later about this same hose going to the mass airflow sensor. Thing is, where I think this goes in the sensor is sealed off with silicone. On the air filter box, where I think the hose attaches, there's a cap on it. So there was never a hose, aside from the one that came with the intake.
Out of curiosity, I removed the silicone to see what was in there, just a hex screw, then sealed it back up as it was. My question is, what is the purpose of this hose? Is it needed? From the looks of it, I've never had the hose and the car has been fine. So should I attached it? Hose doesn't even fit the opening on the sensor so I would have to find a larger hose for the job.
Old Jun 11, 2010 | 02:18 AM
I don't have any extra hose on the 92 either. Going to guess that they supplied a 'one size fits all' kit.
Presume that you are installing on the radiator side of the MAF.
Old Jun 11, 2010 | 11:42 AM
ArmyJag's Avatar
Have you guys noticed any improvement in performance or economy with the kit?
Old Jun 12, 2010 | 02:18 AM
Still standard here, but previous experience shows that anything that increases the sucking or blowing sound tracks (air intake/exhausts) also has a negative effect on economy, due to the direct relationship between the sound input devices (ears) and the volume control (right foot).
Old Jun 12, 2010 | 04:05 AM
Tommahawk's Avatar
I make superchargers for old jags if anyone is interested, what that look like is a big opening with a filter stuck on the end of it, mine supercharger puts the air filter housing under compression, even has a blow off valve so it can fine tuned to suit and for about the same price as you bought your rig for.
Old Jun 23, 2010 | 08:40 PM
estunum's Avatar
It shouldn't be a one size fit all kit, per the description its pretty specific to my car. Plus, the connections to that hose exist. Like mentioned on my first post, there's a place for the hose on the bottom of my air filter, and one on the MAF. Both of which are closed off (a cap on the filter, silicon on the MAF).
Since I never had it, I assume its not needed. I was just curious of its purpose. Or even if not meant for my car at all, I'm still curious of the little hose's purpose.
xjrjag
Oct 24, 2024 03:09 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
cissdm
May 3, 2016 06:02 AM
explorer364
Sep 11, 2015 05:44 PM
1100me
Sep 7, 2015 06:26 AM
