XJ40 ( XJ81 ) 1986 - 1994
Audi ABS sensor functions as a replacement for rear wheel speed sensor
Old Sep 10, 2022 | 10:46 PM
JensenHealey's Avatar
Default Audi ABS sensor functions as a replacement for rear wheel speed sensor
The Audi ABS sensor does indeed work as a replacement for the rear wheel ABS sensor on my 1994 XJ6
I had to make a small bracket to hold it in the correct orientation and at the correct distance out of the hub but now I have a working speedometer in the car for the first time in probably three or four years.
Yahoo!
Old Sep 11, 2022 | 08:05 AM
jerry_hoback's Avatar
Most excellent! Can you pass along the Audi part number and maybe a pic with measurements of your bracket?
Old Sep 11, 2022 | 06:47 PM
I don't know the Audi part number. I bought this sensor on closeout from Rockauto.com a couple years ago.
The brand name was BWD/NIEHOFF and the part number is ABS526 according to the receipt I still have in my email records.
BTW, the end of the attached wiring harness on the sensor does not match the plug on the OEM Jaguar harness so I had to cut the Jag harness connector off and substitute a different plug that would match up with the harness plug on the end of the Audi sensor.
2D view of plate.
Large hole is diameter of ABS sensor barrel.
Small holes are for 6mm bolts.
Close-up of sensor head
Old Sep 13, 2022 | 05:54 AM
BTW, in case others don't realize this the original Jaguar ABS wheel sensor is no longer available from Jaguar.
I have seen some aftermarket listings but they are at crazy prices like this:
https://www.autopartskart.com/jaguar...ed-sensor.html - $463.30
or
https://www.jagbits.com/product/DBC1557.html - $486.56
or
https://www.jagbits.com/product/DBC6247-USED.html - $200 for a USED part
And if your rear wheel sensors fail to function the speedometer and cruise control won't work.
Old Sep 18, 2022 | 10:24 PM
Don B's Avatar
Steve,
Congratulations on making it work, and thank you for sharing the good news with the rest of us!
I assume the thickness of the bracket is important to establish the correct gap between the sensor tip and the reluctor wheel? Can you tell us the thickness of your bracket?
Cheers,
Don
JensenHealey
XJ40 ( XJ81 )
Aug 23, 2022 09:46 PM
brinny
Dec 21, 2020 05:26 AM
Stu Jags
Sep 17, 2019 05:37 PM
Controllie1
Jul 12, 2017 04:14 PM
AlbBolivar
Oct 1, 2014 11:02 PM
