XJ40 ( XJ81 ) 1986 - 1994
Check engine light!!!
Old Dec 28, 2016 | 11:49 AM
Kaiser2's Avatar
Default Check engine light!!!
My name is AL and I have a 1994 Jaguar XJ6 Vaden Plas .... My check engine light just came on & the VCM read Fail 14 ... can someone help me out?
Old Dec 28, 2016 | 01:08 PM
Welcome to the forum AL,
I've copied this question from your Intro to XJ40 forum. Members here with the same model will be able to help.
Old Dec 28, 2016 | 01:55 PM
Lawrence's Avatar
Hi there, FF14 is a code for a coolant temperature sensor out of range (faulty) - Sometimes this can simply be a bad connection at the plug, try cleaning the contacts and clearing the code first.
To clear the code, disconnect the neg battery terminal for a minute. Make sure you have the radio code and leave the doors unlocked when you disconnect the battery.
If the code returns, replace the sensor -
Welsh Enterprises, Inc - Jaguar XJ6(88-94) / XJ40 Fuel/Emissions Switches, Sensors & Injectors Parts - Coolant Temperature Sensor - XJ6 XJS
Larry
Old Dec 29, 2016 | 09:22 AM
motorcarman's Avatar
I uploaded S91_AJ6 4.0 Engine Management in the large file area or GUS should have it on his website.
All you need to know about the AJ6 diagnostics.
bob
Old Dec 29, 2016 | 11:22 AM
Lawrence's Avatar
bob
Ok I see you and Don going on about this Gus guy from time to time, who is he and where is his site?
Old Dec 29, 2016 | 11:36 AM
JagRepair.com - Jaguar Repair Information Resource
Old Dec 29, 2016 | 11:43 AM
Lawrence's Avatar
Ok - THAT site ...thanks for clearing it up
Larry
j2times
May 16, 2017 02:27 PM
Teresa Glanville
Dec 29, 2016 09:16 AM
Shivs
Oct 6, 2016 04:18 PM
JB73
Oct 2, 2016 05:22 AM
Rogelio Serrano
Oct 1, 2016 05:45 AM
