XJ40 ( XJ81 ) 1986 - 1994
Check Engine Light On and Off
Old Dec 15, 2019 | 09:49 PM
VandenP's Avatar
Default Check Engine Light On and Off
Hey All!
Happy Holidays<3
I have a question regarding my 1990 Vanden Plas. My check engine light turns on sometimes but I bypass it by turning the car off and then on again and the light disappears, is this ok? Can anyone tell me if there is something wrong with darling.
Best Wishes,
Old Dec 15, 2019 | 11:32 PM
Lawrence's Avatar
What is the year and VIN of your car?
Larry
Old Dec 16, 2019 | 12:14 AM
VandenP's Avatar
Hey Lawrence,
It's a 1990 Vanden Plas with almost 90k miles on the dash. My VIN is SAJJKYLD4LS593006. Is this a common thing that happens to the car electrically? It also does it with my Light Bulb on the dash, here and there it will go on and off but everything runs well and smooth. I did check that my oil is low and has a leak within the engine. I know my Power Steering Rod is leaking and the mechanic said it'll cost me a good amount to repair. I got the car in June with 87k miles and have driven it daily since it's my first and only car.
Thank you for your time,
Old Dec 16, 2019 | 02:15 AM
Lawrence's Avatar
It may be that the check engine light is on, but because of an intermittent connection, it appears to go on and off? You can check if there any trouble codes stored if you turn on the ign (but don't start the car) and then press the VCM button.
If you have a check engine fault, you'll see a code displayed on the dash, e.g. Fuel Fail and a number or FF and a number.
The display instrument binnacle solder connections do fail on these cars and can be repaired by reflowing the solder joints.
Leaks, although annoying and messy, won't cause the check engine light to illuminate. Only a sensor can report a fault that causes the lamp to light. On a late car, the check engine light won't reset each time you switch off the car, at least it won't on my 94 ..maybe someone with a 1990 car can confirm if the lamp resets when the engine is restarted?
Larry
Old Dec 16, 2019 | 08:46 AM
Don B's Avatar
Hi VandenP,
Congratulations on your low-mileage XJ40! We'd all love to see some photos when you get a chance to upload some.
If you'll follow Larry's instructions for retrieving any diagnostic trouble codes, you can reference this chart to find the area of the malfunction:
Post your codes here and we'll try to help you resolve them. Note that while most of the codes are related to emissions, the problems that can trigger some of the codes can lead to running conditions that can damage expensive components such as catalytic converters, valves, etc., so you don't want to ignore what your Jag is trying to tell you.
Cheers,
Don
ek993
Oct 24, 2014 07:34 AM
Boeingtravel95
XJ40 ( XJ81 )
Jan 9, 2013 12:31 PM
jazzwineman
17
Jun 29, 2011 05:57 PM
rabbits2
May 2, 2011 01:56 PM
XK8Guy
Apr 16, 2008 11:51 AM
