XJ40 ( XJ81 ) 1986 - 1994
continues to run with key removed
Old Apr 16, 2020 | 04:38 PM
newguy12's Avatar
Default continues to run with key removed
Hello. I have a 1988 xj6. The car starts fine and runs. When I turn the key off and remove it the car still runs (its not dieseling from carbon) and the dash lights and radio stay on. When I unplug the ignition switch with the car running it continues to run. to get it to turn off I pull the ignition relay on the passenger side dash. I swapped that relay and still the same. I don't think its a bad igniton switch because when I turn the key to accessory position 2 the windows go up and down and turn the key back they wont work. I also swapped the relay called "main relay" and no difference. Any ideas? I was thinking its a wire touching ground constanstly… thank you.
Old Apr 17, 2020 | 06:15 AM
jerry_hoback's Avatar
You can look at a diagram of the ignition system in the stickies at the top of this area. It sounds like you have done a fair amount of diagnosis already. Did this problem start suddenly? I suggest checking the wiring in the engine bay for breaks or ( god forbid) chew marks. Also and as always check grounds. Sorry I can't help more..
Old Apr 17, 2020 | 12:37 PM
newguy12's Avatar
Yea it just started randomly. I looked at the schematic and it looks pretty simple. Still cant figure this out. Ill have to look for a wire. thank you.
50cool50
Mar 22, 2019 12:19 PM
littleguy
XJ XJ12 ( X305 )
Nov 20, 2015 03:37 AM
fibereng
May 28, 2010 10:02 PM
darnell8228
Feb 1, 2010 12:06 AM
cooke
Sep 24, 2009 12:02 PM
