XJ40 ( XJ81 ) 1986 - 1994
Ff22 - FIXED
Old Dec 6, 2011 | 01:40 PM
mrtalkradio's Avatar
Default Ff22 - FIXED
Finally this car (90 VDP) gave me a code, 22. I have done the suggestions as the hynes and the AJ6 system diagnostic guide have suggested. Still no sound of that fuel pump giving that initial burst. I even have another working ECU that I tried. Anyone else tackled this 22?
Old Dec 6, 2011 | 03:35 PM
Default Blue ECM
I am a little confused on how to count the pins on the blue ECM connector.I am not sure which way to start counting. I need 7, and the color code of the wire is KN, that also has me confused.
I am trying to diagnose as pic one describes with this circuit issue. Pic 2 and 3 is the connector, and the colored wires. Any help would be great.
Attached Thumbnails Ff22 - FIXED-circuit.jpg   Ff22 - FIXED-ecm1.jpg   Ff22 - FIXED-ecm2.jpg
Old Dec 6, 2011 | 05:45 PM
Default Seized Fuel Pump
I had a friend come over, because trying to work on that fuel pump issue by myself was difficult. He was able to get under there while I turned the key, the fule pump was seized. Car is running again. I did fix a few loose connections on that blue connector to the ECU, the 22 code is gone. Thank you gentlemen. I'm on the road again.
Old Dec 7, 2011 | 04:56 AM
Cadillac's Avatar
Thanks for the update , good to see it's fixed
Old Dec 7, 2011 | 05:42 AM
Hey Mr T.....thanks for coming back and advising of the fix
aholbro1
Dec 29, 2024 06:46 PM
Arne
Aug 18, 2024 12:08 PM
GordoCatCar
Jan 2, 2017 01:10 PM
hhv00586
Sep 18, 2015 08:59 AM
JagLove86
Sep 6, 2015 10:36 PM
