XJ40 ( XJ81 ) 1986 - 1994
First Jag, and first car
Old May 5, 2009 | 09:51 AM
Geofux's Avatar
Welcome to the forums!
A Jag XJ6 is definitely an amazing first car, but be prepared to spend money on repairs and general maintenance...
If you have a lot of questions, you might as well fire away. Some of us might only be able be somewhat knowledgable about some things while other things not so much.. (..like myself).
A rough idle could be caused by something as simple as bad plugs, wires, air filter, vacuum leak or it could be distributor, fouled injectors, a sensor issue, etc.
I'm taking a bit of a guess but that's what I would look at first. Go look at all the easy things and then go for the more difficult stuff. The easy stuff you probably want to have a go at by yourself (or with a knowledgable buddy) because it'll be cheaper than taking it to a shop to diagnose, especially if it ends up being an easy fix.
Old May 5, 2009 | 04:02 PM
Cadillac's Avatar
VCM button is located around car computer buttons and next to windshield wiper stalk . Take a closer look you should see it .
Your '94 should be compatible with OBD I code reader but I think any pro code reader will be able to read your codes too .
Isoruku
Jun 19, 2020 12:54 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
jdzubas
Oct 4, 2015 09:14 AM
danpop
Sep 3, 2015 08:06 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
