XJ40 ( XJ81 ) 1986 - 1994
fuel filler flap
Old May 11, 2008 | 10:19 AM
Cadillac's Avatar
Default RE: fuel filler flap
The fuel filler doors are real problems on the earlier XJ40s as well.In order to get itopen , just push down the lowest side on the flap to the left tail lights ,it should pop open .If not, openthe trunk ,go to the left side and lower thetrunk linings .Look at around the left trunk hidges there should be a tiny white switch .Just push it that's another trick to open it .
Late model XJ40's fuel filler doors are more reliable .You can easily open them by just pushing up even w/ your little finger
Old May 12, 2008 | 01:49 AM
JagtechOhio's Avatar
'91 doesn't have the early solenoid release latch for opening. I believe '90 and '91 have the remote release handle and cable set up, deleted in '92. You can still open yours manually inside the trunk, and probably find that the clip for the release cable is broken at that end.
1100me
Jul 24, 2023 06:10 PM
Razor
Aug 28, 2019 08:34 PM
njburlington
Sep 24, 2015 08:40 PM
puddled
Sep 22, 2015 03:57 AM
1100me
Sep 7, 2015 06:26 AM
