XJ40 ( XJ81 ) 1986 - 1994
Gasoline Smell XJ6 1992
Old Feb 26, 2020 | 12:48 AM
Jairo Rivera's Avatar
Default Gasoline Smell XJ6 1992
Start my car after a year and you feel a strong smell of gasoline inside,I check the engine, trunk and below the car and there are no visible leaks
Thanks for considering my request!
Jairo
Old Feb 26, 2020 | 08:45 PM
Don B's Avatar
Hi Jairo,
Open your trunk and sniff around the top of the carpeted panel at the bulkhead to see if the gasoline smell is stronger there. If so, I would suspect a leak at the "evaporative flange," the plastic cap on the top of the fuel tank. There is a foam sound insulation pad on top of the tank and if the evaporative flange is leaking, the pad becomes saturated with fuel.
Cheers,
Don
AML
Apr 10, 2020 08:18 AM
Rkr45
Oct 6, 2017 09:11 AM
dtony
Jun 16, 2017 11:16 AM
rsperle
Jul 3, 2015 08:46 AM
XJrrr
Aug 3, 2012 06:54 PM
