XJ40 ( XJ81 ) 1986 - 1994
Glove compartment won't lock closed
Old May 6, 2011 | 12:05 PM
Steve W's Avatar
Default Glove compartment won't lock closed
Anyone ever have this happen? I might just try using WD40 on it first.
Old May 6, 2011 | 02:49 PM
Do you mean it won't stay shut, or won't lock with the key.
If it won't stay shut, then from experience the tang in the latch has most likely broken.
There is a spring type assembly within, that pushes the tang into position.
In my case, the blob of pot metal holding it broke off. Result, glove box falling open.
Old May 6, 2011 | 11:17 PM
Steve W's Avatar
When I close it it won't click shut and stays slightly open. The key won't lock it either.
Old May 7, 2011 | 12:57 PM
mrtalkradio's Avatar
before shutting be sure to turn the outside switch to 12 o clock. You may have a sticky switch like mine. I took mine apart and it still won't return to center. If its in center position when you shut it and it still won't close, you need a new assembly.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
BadKat174
May 26, 2023 12:29 AM
XJsc-guy
Nov 23, 2015 01:56 PM
