XJ40 ( XJ81 ) 1986 - 1994
Help please oil leak
Old Jul 26, 2020 | 09:25 AM
Craig Geske's Avatar
Default Help please oil leak
Have a car that has been stored most of its life , have all books and papers to the car including window tag new. ...... FRONT CRANK TIMING SEAL REPLACE , no videos out there on 3.6 crank seal . I have seal from Jag supplier. But is it installed inside timing cover, or can it be removed from outside, behind hub for belts? Also little help on belt loosen , remove and tighten , on this motor ,
Front seal crank leak , need senior advise please
Old Jul 26, 2020 | 10:40 AM
aholbro1's Avatar
Welcome to the forum, Craig!
Unfortunately, you've missed the proper forum by just a smidge. Absolutely gorgeous car, but it's the immediate predecessor of the X300 (I think)
FWIW, the 4.0L front seal, found in the X300 is accessible directly behind the crank damper, without disturbing the timing cover. Wait for Bob to see this one, he knows for certain, or for a mod to move you to the proper sub-forum. Speaking of moderators, make sure you've posted an intro in the new members section, and read & heed the forum rules and guidelines there so you will be well-launched on the path to full membership!
Again, beautiful car!
Old Jul 27, 2020 | 12:12 AM
Parker 2's Avatar
How much you want for that
Year ?
From my understanding the last year or so of the X40 production changed to a round headlight lens
Old Jul 27, 2020 | 03:38 AM
countyjag's Avatar
There was always a round headlight version of the XJ40, it was only the sovereign and Daimler variants which had the rectangular lights. May differ in export markets.
Reverting to the seal, it can be changed without removing the timing cover.
Old Jul 29, 2020 | 09:54 PM
Don B's Avatar
Hi Craig,
Welcome to the Jaguar Forums! It's great to have you with us!
That is an absolutely stunning Jaguar! The factory project code is XJ40, so I have moved your thread here from the forum for the X300. Here you will find knowledgeable owners of similar cars.
As countyjag stated, the front crankshaft oil seal is replaceable without removing the timing cover, but you do have to remove the crankshaft pulley/harmonic damper. Here's the parts diagram showing the crank seal, Part 10 in the diagram below. You may also want to replace the intermediate shaft seal, Part 9, while you're at it.
You can see this diagram and the part identifications and part numbers at this link:
https://parts.jaguarlandroverclassic.../brand/jaguar/
Please do visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Old Jul 29, 2020 | 11:18 PM
Lawrence's Avatar
So yes, as the lads above said, pretty car!
Take off the belts and then undo and remove the crank damper/harmonic balancer, seal is right there underneath.
To remove the harmonic balancer, here's how I did it.
https://www.jaguarforums.com/forum/x...-issue-221378/
Joe has some great tips also with his youtube vid apart from the fact that the threads in the crank damper are not metric.
Your car looks like an earlier model than mine and Joe's (94's) so you won't have electric fans maybe
cheers
Larry
Mish_Mish
Sep 29, 2016 09:50 AM
bocagq45
Oct 29, 2014 04:41 PM
osyris
May 1, 2014 05:39 PM
o1xjr
Mar 30, 2014 05:15 AM
blast20
Jan 5, 2012 08:59 PM
