XJ40 ( XJ81 ) 1986 - 1994
Instrument Cluster dead
Old Jul 16, 2012 | 02:14 AM
NL30ump's Avatar
Angry Instrument Cluster dead
1990 XJ6 instrument cluster gauges have stopped working. The oil pressure, water temperature and tachometer do not work. The speedometer, gas gauge and volt meter seem to be working. All lamps appear to be working along with the odometer. I have checked all fuses that I can find and all are intact. Anyone have any suggestions?
Old Jul 16, 2012 | 12:37 PM
mrtalkradio's Avatar
Welcome to the forum. Go introduce yourself in the new members area when you get a chance, then go et a Haynes manual for your car. Your going to have to pull the cluster out. You can't check the connections in the back unless it's out.
Old Jul 18, 2012 | 12:07 AM
NL30ump's Avatar
Arrow
I have a Haynes manual and a service manual that I purchased online. Neither of them give a decent explanation of how to go about testing gauges, especially on the tachometer. My next move is to test the wiring from the sensor to the ECU, because none of the wires to the instrument panel match the wires from the sensors.
Old Oct 21, 2012 | 01:27 PM
joneswendell001's Avatar
Hello. this is joneswendell. I have a similar issue. I have a 1989 vandan Plas and the instrument cluster gauges have stopped working also. The oil pressure, water temperature and speedometer do not work. The techometer is the only gauge that seem to be working. I have checked all fuses that I can find and all are intact. I hope you find a solution. Please share it with me if you do
Old Oct 21, 2012 | 02:58 PM
Rob Evenson's Avatar
Default Instrument Cluster dead
Joneswendell & NL30ump
I have an 89 XJ6 with digital instrument cluster is yours the same with a digital display? It matters in the method of repair.
Old Oct 22, 2012 | 07:40 AM
NL30ump's Avatar
Cool Instrument Cluster dead
Hi Rob,
Thanks for your response. I have a full analog instrument cluster. I have pulled the cluster out and cannot figure out how to test the gagues. I have also pulled the ECU out and none of the wires match the wires coming from the devices. I am stumped.
Old Oct 22, 2012 | 07:46 AM
NL30ump's Avatar
joneswendell001
Garage is empty, add now
Hi Joneswendell,
I am still struggling with this issue but I will let you and everyone else know when I solve the problems.
joneswendell001
Old Oct 22, 2012 | 07:50 AM
NL30ump's Avatar
Question Instrument Cluster dead
Hi Joneswendell,
Old Oct 22, 2012 | 11:35 AM
NL30ump,
Have you ever slapped the dash cluster and the guages behaved for a short time, them resume erratic behavior?
Since you have the cluster out (I think you said you pulled it) go ahead and open the cluster and examine the connections where the pigtails terminate on the boards. I researched your problem in some other forums and the similarities are identical, except for the actual display (analog vs. digital). You may find poor solder/connections on the boards. Telltale signs would be significant discoloration on the points. Mind you, I have never opened an analog cluster, but our MY's are close, mine was produced late 89, the VIN is 583143. Also, clean any and all connectors while the cluster is out with an electronics cleaner.
My fix was definitively poor solder connections. Repaired them about six years ago and had no issues since. I really doubt you have three different sending units acting up at the same time. I also recall my tach (both the tach and speedo are analog, everything else is digital) acted up as well, it would bounce then go to zero, then bounce..... you get the idea.
Hi Rob,
Old Dec 26, 2012 | 06:10 PM
NL30ump's Avatar
Hi Rob,
I appreciate your response. Sorry about taking so long to respond. Too many issues with daily drivers to focus on the Jag right now. Anyway, I checked all of the connectors and cleaned them with electrical cleaner. Nothing. All of the gauges have ribbon connectors, so I am not sure what to do with them. They all appear to be fine.
My next approach is going to be grabbing an instument cluster from the local pick-n-pull when they get one. I am with you, I doubt very seriously that all three sensors went bad at once.
Gremlins.
mhamilton
Oct 8, 2015 02:17 AM
mrplow58
Sep 30, 2015 08:56 AM
redxk8
Sep 30, 2015 08:18 AM
oldjaglover
Sep 29, 2015 03:27 PM
