XJ40 ( XJ81 ) 1986 - 1994
Jaguar PDU Manuals & Software
Old May 23, 2023 | 09:33 AM
  #201
JensenHealey's Avatar
Originally Posted by Gijzzy
As far as I am aware of, there is nobody who tried to make a system that could talk to the cars jet. On a Reddit forum ( https://www.reddit.com/r/Jaguar/comm...le_diagnostic/ ) there is somebody asking for a PDU so they can try to copy the system. I am not in contact with them and don't know if they have made any progress. Where are you located if I may ask, I know a few PDU's in the USA if you really need one. I even might be able to make a working set for you but it comes with a price.
I am in NE Ohio USA (says in my signature)
Old Oct 28, 2023 | 01:18 PM
  #202
Gijzzy's Avatar
Is there somebody who can help me with a known good .iso file of the Ford FDS2000 disc 32 (or 31) ? I downloaded disc 31 from: https://jaguar-x308.hpage.com/ford-f...00-archiv.html but isn't working.
Maybe it is my hardware that is giving me problems but never had problems with Jaguar disks. Trying to help a FDS friend in Germany to get his system running again.
Last edited by Don B; Oct 30, 2023 at 11:58 AM. Reason: Removed reference to posts that have been moved.
Old Oct 30, 2023 | 04:06 AM
  #203
ted7t9's Avatar
Hi Gijzzy,
I have a .iso for disc 31 which appears to be OK (it mounts on a virtual CD drive on my laptop and the files look to be navigable in windows explorer) - would you like a copy? My .iso for disc 32 is also corrupt, which makes me suspect I downloaded it from the same location as you!
Old May 15, 2024 | 12:49 PM
  #204
luciod2012's Avatar
Default Need board!
No problem please try to send me a personal message.
hi I could not send you a PM for whatever reason
. My email is luciod2012@gmail.com. Im in need for one of those boards. Also the unit charges fine but no red light
Old Mar 22, 2025 | 04:28 PM
  #205
FordFDS2000's Avatar
Dear Gijzzy, i tried to PM you but i see no option for it, strange.
Do you still have those boards for the CD drive, i'm in need for one, to get FDS2000 working to test my Escort Cosworth which i love.
Can you mail me at: Personal Contact information Removed from Public Forum please no spam.
Thanks,
Fran,
Last edited by Don B; Mar 23, 2025 at 02:44 PM. Reason: Remove personal contact information from public forum.
Old Mar 23, 2025 | 02:09 PM
  #206
Gijzzy's Avatar
Can you mail me at: please no spam.
Thanks,
Fran,
I have sent you a email! You can remove your adres now from the forum to avoid spam.
Last edited by Norri; Apr 17, 2025 at 02:43 PM. Reason: Removed email address from quote
Old Mar 23, 2025 | 03:48 PM
  #207
Hello Gijzzy, i've received your mail, thanks Fran,
Old Apr 4, 2025 | 11:17 AM
  #208
Vitek's Avatar
Default pcb kind request
Hello, could I kindly ask you to send me details on buying one of your PCB boards for fds 2000. My email is thank you
For people who are having problems with the Sony CD drive, I have a solution for it!
I am building new circuit boards which are a direct replacement for the original board inside the Jaguar PDU (Ford FDS 2000) if the CDrom player fails. No need for any soldering just 2 screws and its is plug and play. The original players are non ATAPI drives as mentioned earlier and fitting a new modern player will not make the system working again. This circuit board makes it possible to fit any ATAPI drive, also giving much higher loading speeds as the original Sony only had 1 speed. So this board can be used as an upgrade as well.
If you are interested please sent me a PM.
Old Apr 5, 2025 | 04:07 AM
  #209
Gijzzy's Avatar
No problem, i will contact you. You can remove your email address to avoid spam.
Last edited by Norri; Apr 17, 2025 at 02:45 PM. Reason: Removed email address from quote
Old Apr 5, 2025 | 10:31 AM
  #210
monkfe's Avatar
Gjizzy, can you reach out to me ref your board and some other questions...thanks...
Old Apr 5, 2025 | 10:40 AM
  #211
monkfe's Avatar
my email PERSONAL CONTACT INFORMATION DELETED FROM PUBLIC FORUM - PLEASE USE PRIVATE MESSAGE.
Last edited by Don B; Apr 6, 2025 at 07:21 PM. Reason: Deleted personal contact information.
Old Apr 17, 2025 | 06:09 AM
  #212
monkfe's Avatar
So, I'm in the process of getting my PDU up to speed with the help of this really great thread. So I have a question on the PDU battery replacement. I've seen people here suggest the 7.2v battery as a replacement. When I received my unit recently, I pulled what appeared to be a factory battery, it was wrapped in electrical tape, and then another thick layer of protective plastic wrap as well. See pics of what was left over afterward. As you can see this is set up with two nicad batteries in series, with an exra two in parallel for more longevity. So if this is the case, its only a 2.4~2.5v battery. Not sure how you guys got to 7.2v. This of course assumes this is the correct battery, but the connector seems correct and it fits perfectly in the battery compartment, so thoughts here?
Old Apr 17, 2025 | 02:37 PM
  #213
I have the FDS2000, the same as your Jaguar PDU, just toke out the battery and what i know is 7,2 Volt/ 4000mAh, no doubt.
It has 2 x 3 Cells in series, 1,2 Volt/ Cell.
I also i'm looking for the CD's and FDS2000 manuals, anybody have a link where i can download these??
Best Regards,
Fran,
Old Apr 17, 2025 | 02:45 PM
  #214
monkfe's Avatar
Best Regards,
Fran,
Ok, are you sure that was the original battery?...I believe the PDU software is on the first page, I've also seen the manuals under a response here on this thread...
Old Apr 17, 2025 | 02:58 PM
  #215
Hello,
It was not the original battery, the previous owner replaced it with this 2 x 3 cell 7,2 Volt one, from what i've saw in the Jaguar training
PDU introduction and PDU module II, there on page 4-2 the battery is made of 6 cells next to each other.
I found this on this forum, perhaps in this thread, i don't know for sure.
Are you sure that the Ford CD's are on this forum, this thread? i only saw Jaguar CD's.
Fran,
Old Apr 17, 2025 | 03:05 PM
  #216
monkfe's Avatar
Hello,
Fran,
Sorry just the Jag , no Ford. So if there are six cells, they could be in series parallel like mine were, so maybe 3.6v?...I'll take a look at that page.
Old Apr 17, 2025 | 03:12 PM
  #217
You need 6 cells in series to get 7,2 Volt, not parallel, and of course not bigger then your space can hold.
Some used a battery for RC cars, i think mine lookes like that, longgg ago i used the same battery for my RC cars,
they where Nicad, and now the best alternative are NiMh with more power (mAh).
Fran,
Old Apr 18, 2025 | 06:12 AM
  #218
Vee's Avatar
Vee
I can share pics of the battery pack I made for my PDU
i had to transplant the wires and circuits to my battery pack from the original one.
Old Apr 18, 2025 | 06:20 AM
  #219
Vee's Avatar
Vee
Actually, that was for my WDS.
the PDU Batteries were these:
Old Apr 18, 2025 | 06:34 AM
  #220
monkfe's Avatar
Seems to be quite of bit of variety with these batteries...But obviously the 7.2 works so I'll go with that..ty
