XJ40 ( XJ81 ) 1986 - 1994
JDU or PDU dtc scanner
Old May 22, 2012 | 03:50 AM
reedster's Avatar
Default JDU or PDU dtc scanner
Still trying to resolve the mystery code causing my 1990 xj 6 transmission to remain defaulted to limp mode. replaced tcm, decoder module , clean rotory switch & potentiometer.. back probe most of the in / out @ tcm. no trouble code on vcm. I cannot find anyone that has working jdu / pdu dtc scanner..
Is this the only way to retrieve dtc for transmission in my car ? Anyone know of working jdu / pdu dtc scanner near seattle washington ? local expert says replace tps,, but I backprobe tested it @ tcm and it is .30 - 5.00 v .. within spec or very close as far as I know. Thanks to motorcarman I have the wiring sckematic for tcm & associated controls. Really could use a scanner though!!
Old May 30, 2012 | 08:42 PM
limegreenclown's Avatar
tps should be .6v at closed throttle, that may be your issue. Haynes says .5 but from experience it needs to be at .6v
Old May 30, 2012 | 09:55 PM
motorcarman's Avatar
JDS is a REALLY old system that will probably not help and I doubt you will find a functional unit.
PDU is the only system that will work for the ECM,TCM,ABS for the XJ40. WDS was supposed to be a replacement and we got the cables to connect to the car in the WDS setup package but the software NEVER materialized.
Keep looking??
bob gauff
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
jjmiah217
Sep 28, 2015 09:09 AM
shootingbrake
Sep 23, 2015 10:54 AM
NTL1991
XJ40 ( XJ81 )
Sep 20, 2015 06:22 PM
