XJ40 ( XJ81 ) 1986 - 1994
Just picked up an 88 XJ40
Old Aug 24, 2007 | 04:13 PM
Cadillac's Avatar
Default RE: Just picked up an 88 XJ40
Welcome !
As I recall, you should press and hold the button which is related to VCM reset . As for now working properly AC , you can get the whole unit .
BTW, if your car comes with self levelling you should be very warry about your hydraulic system and just use the green stuff otherwise your suspension system goes lemon which is too expensive to fix . You should see the correct level when opening the hood . If the color of it is red , you just top off the reservoir .
Hope you enjoy it
Old Aug 26, 2007 | 09:57 AM
93xj6's Avatar
I dont think the levielin system is that big of a concern, is it caddy. mine has been fine
Old Aug 26, 2007 | 01:47 PM
Cadillac's Avatar
Keep in mind, you have a late XJ40 . In addition post '91 (as I recall ) don't come with the hydraulic system which means less trouble unlike '88 if poor maintained
Old Aug 26, 2007 | 03:48 PM
93xj6's Avatar
o ok. I tasnt sure if they was all the same.
Old Aug 27, 2007 | 11:40 AM
XJ40ish's Avatar
I hope that you will still feel you got a better deal once you start getting into thecare and feeding of a Jaguar.
A bad cat can vacuum out your wallet with alarming speed and regularity. Early versions of the XJ40 (ie 1988 - 1990) were plauged with many electrical/mechanical problems.At the end of the series (1991 -1994) most of these problems had beenengineered out of the design. Just when they got it right, they stopped production. Now that you own one, there is one thing you need to learn...Nothing in a Jaguar is minor!You can only ignore or bypass warning lights for so long. On mine all the lights come on at start and they all work.If one stays on, it is time to get it looked at. An easy reference is if the lamp is yellow, it is a caution and can be left for a short while. A red lamp means something requiring immediate attention or you will hear that familiar sucking sound from your wallet. If all the warning lights do not come on at start, I'd suspect that a previous owner has had some bypassed.
Good luck my friend and hang around in here a bit, you'll need some strong shoulders to cry on.
Old Aug 27, 2007 | 05:28 PM
ken@britishparts.com's Avatar
I think I have a good deal on the 1st cat. Let me check it out and get back to you. The bulb failure modules do go out. Do you have trouble from any of the lights?
Old Aug 28, 2007 | 10:07 AM
XJ40ish's Avatar
Love the car man it looks nice. I didn't mean to scare you off, but it would in my humble opinion not hurt to have a competent Jaguar shop giver her a good look over so you know what you're up against. I decided to pass on a really pretty XJin favor of a slightly scuffy one that I knew to be mechanically straight as the reliability was more of a factor to me. Starting with a clean slate mechanically speaking, I can have a beter handle on the maintenence end. You can ask Ken, but I understand the early XJ40's to be somewhat problematical and he can likely give you some tips on what you should be looking for.
Old Aug 28, 2007 | 11:47 AM
I have a new front cat for $275.
Rocky15
Oct 12, 2015 03:42 AM
rldvols
Oct 7, 2015 10:01 PM
JaguarSV8
Oct 1, 2015 01:58 AM
Johnken
Sep 30, 2015 02:46 PM
