XJ40 ( XJ81 ) 1986 - 1994
View Poll Results: Lifting engine out
YOLO, keep them together
100.00%
Drop gearbox, lift engine
0%
Drop engine and gearbox, lift the body
0%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Lifting 3.6 with ZF
Old Apr 2, 2026 | 11:28 AM
Joliette's Avatar
Default Lifting 3.6 with ZF
Hello guys, your experience is needed. I lifted 350sbc with turbo 400 before, but somehow have no good feeling about this.
Would you lift 3.6 with automatic gearbox (both dry)
Or should I split them.
It is 2t crane at 1to setting
TIA!
Old Apr 4, 2026 | 07:36 AM
jerry_hoback's Avatar
I think it depends on what I plan to do with either or both....
Old Apr 4, 2026 | 10:14 AM
Wilfred88's Avatar
Should be fine. I have done it multiple times with the 4.0 with zf box, also 2ton lift. No problem.
Its an aluminum block, weight is less than what you would think
Old Apr 4, 2026 | 04:53 PM
Joliette's Avatar
Both restore and use, though in different cars.
Joliette's Avatar
thank you
Old Apr 5, 2026 | 07:17 PM
i purchased an eng/trans unit complete from a wrecking yard. I built a cart to put therm on as a unit and figured they weigh about 850 pounds together in order to get proper wheels for the cart.
Old Apr 5, 2026 | 07:53 PM
Don B's Avatar
Hi Joliette,
I can't tell in the photo how your load leveler is attached to the engine, but it will help if you can attach it in a lengthwise manner that will give you the ability to tilt the front of the engine up as you lift it out, Your hoist looks like a newer version of the one I own, which is perfectly capable of lifting both the engine and transmission together.
Cheers,
Don
Old Apr 6, 2026 | 10:51 AM
Joliette's Avatar
Thumbs up
Thank you guys for support, so in the end it was way easier than the dimensions would suggest, the engine is way lighter than diesels I usually have to deal with. So my red one gets a new rebuilt gearbox, my green one gets a new engine and gearbox and they will both be ready for next 40 years of fun.
I fixed the crane on rear exhaust and in front I rotated the engine mount and fixed it on that so it was naturally forward backward balanced and tilting. It touched the engine bay on the front as I was sliding it out, but I removed the grille so it does not get damaged and it needed only slight lift by the gearbox to clear it. I was able to do it with my missing muscles so, weights really not much.
When I will be putting it back, I will move the front attachment to rear engine mount screw (one is enough). I was just too scared seeing the size so as always overdid it.
Old Apr 6, 2026 | 10:55 AM
Joliette's Avatar
View from the other side, for future references. Maybe it will help someone.
And yes, crane was not even sweating. Actually when I had the engine on the ground (it looks scary big) I was able to lift one and other side to move it around on the ground. So it really could not be too heavy as I am just a little 53kg girl and muscles just enough to fight gravity.
Old Apr 6, 2026 | 12:04 PM
Don B's Avatar
Joliette,
Well done! And thank you for posting the great photos - they will be helpful to other members in the future.
Cheers,
Don
Old Apr 6, 2026 | 12:25 PM
Joliette's Avatar
Thank you Don, I will keep updating the thread as both gets fixed.
This forum has been only helpful to me so far and want to give back as much as I could (also because I know I will need lot of help in the future as well with my collection lol).
Old Apr 30, 2026 | 03:44 PM
Joliette's Avatar
File Type: mov
Old May 1, 2026 | 09:56 AM
Wilfred88's Avatar
Leaky exhaust? Sounds very rough.
Old May 1, 2026 | 11:34 AM
Joliette's Avatar
there was no exhaust at all yet
Old May 1, 2026 | 01:10 PM
Don B's Avatar
So the red one got the rebuilt gearbox, right?
How is the green one coming along?
Old May 1, 2026 | 01:25 PM
Joliette's Avatar
yes.
The green one now sits outside, waiting until I have time to rebuild the engine and the gearbox. I do not really rush it, want to make a video about both and have many others to drive. So will be more like mild general restoration of the whole car. It was ok, just having 20 small things getting on my nerves especially after I had an accident with it..
Old May 1, 2026 | 02:20 PM
pdupler's Avatar
I was going to see if anybody mentioned disconnecting the engine from the transmission and lifting it straight up. I discovered that I could pull my XJ8 engine from the side which came in handy since I didn't have anybody around to help to remove the hood.
I'm very intrigued by your workshop photos. I don't think I could get away with having glass nearly floor to ceiling all the way around like that. I'm too clumsy. But I like it. Looks good!
Old May 1, 2026 | 04:33 PM
Joliette's Avatar
If i was only after engine, I would probably do that, but I wanted to rebuild both engine and gearbox anyway. But removing engine with hood on? That must be something.
Removing hood from XJ8 is not that difficult, you can close it on a foam (i used a camper mattress), unbolt it and then lift it up, it is very light.
From red one i took out only gearbox, just lifted the car up on jack-stands and dropped the gearbox on a creeper (it survived).
And thank you, I love my workshop, was a life long dream to have something like that and love the features it has compared to regular workshops. Now I am still searching something bigger, as pure business decision, but will not be without a compromise very likely.
Tiepolo
Oct 28, 2023 03:45 PM
Smitty99XKR
Sep 11, 2022 03:41 PM
daz2708
Nov 14, 2021 10:47 PM
jagtoes
Nov 14, 2017 09:59 AM
steve_k_xk
May 14, 2016 04:31 PM
