XJ40 ( XJ81 ) 1986 - 1994
Newbie here with a starting issue..
Old Jul 21, 2009 | 12:33 AM
TheRooki3's Avatar
Default Newbie here with a starting issue..
Hey guys....just got a 93 xj6 today (for cheap in hopes i can fix it)...this is basically what happens..i put the key in the ignition (in park with the doors locked) and turn....and nothing! No cranking from the starter at all...i just turn the key and i can hear the fuel pump...anybody perhaps provide me of a walk through of what i should do? Or perhaps a solution? Thanks in advance....
P.s. my apologizes to the mods if i've posted this in the incorrect thread column...
Old Jul 21, 2009 | 02:48 AM
Cadillac's Avatar
Welcome, I hope your battery needs replacement I would go that way first .
Old Jul 21, 2009 | 11:57 AM
TheRooki3's Avatar
Hey Caddy, I appreciate the warm welcome....i have an update..i checked a silver relay/relay for the starter (on the firewall) and made sure that worked first (along with the other relay on the firewall (which they did when appling positive to either 85/86 and grounding 85/86) sprayed contact cleaner where the relays rest and with my digital multimeter i tested for constant which was at 30 ....i then made a jumper cable from 30 to 87 to see if the starter even works (since i don't hear it cranking) and when i did all i hear was a faint hiss/fizz ....i tried it a number of times and that's the sound it made....can i assume at this point that the starter is the culprit?
Old Jul 21, 2009 | 12:10 PM
ken@britishparts.com's Avatar
If you powered it directly, I'd say you found it.
Old Jul 21, 2009 | 12:17 PM
TheRooki3's Avatar
That's bittersweet i guess,lol....i guess i'll do a search on how to change out one of these babys....how would you rate it? ...pretty simple? I don't have a garage or anything....although i was blessed with a nice sized (open) parking area....
Old Jul 21, 2009 | 12:34 PM
As I recall, the top bolt is a pain. It makes up for the ease of the others. I may be wrong here, so wait for a second opinion, but I believe the top bolt takes a 12 point swivel socket with a long extension. Wait for someone to confirm this. I may be confusing it with a V12 starter.
Old Jul 21, 2009 | 01:27 PM
TheRooki3's Avatar
if you're right about this then this is going to suck
Old Jul 21, 2009 | 02:29 PM
JagtechOhio's Avatar
Your post says you have a '93 XJ6, which does not have a starter relay on the firewall.
Old Jul 21, 2009 | 04:28 PM
TheRooki3's Avatar
I'm new at this and i apologize for my ignorance....Yes i believe it's a 1993 Jaguar XJ6 (according to the tag on the back) .....is there a way i can confirm this? Again i'm new to the Jaguar world...i had a bunch of relays on the firewall (passenger side) ...1 black one, 1 silverish looking one, and i believe 4 green ones...now i have more questions lol....
1.) What where those relays for that i cleaned?
2.) any idea where that starter is on this model?
Thanks so much for everybodys help
Old Jul 21, 2009 | 05:40 PM
1993 has one gas tank, rectangular headlights and taillights, 15" Roulette wheels with a full hubcap secured by an allen screw.
The 10th digit of the VIN number denotes the year of the vehicle. For a 1993, that would be a "P".
If the car is a two door, it's an XJS.
Old Jul 21, 2009 | 06:23 PM
TheRooki3's Avatar
Talking
It's a 4 door....the headlights are rectangular, as are the headlights....i'm not too sure about the rims (i'll check) and same goes for the VIN ....the kid that sold it to me said it was a xj6 ...but i've own just about every car known except for these art museums on wheels....
Old Jul 21, 2009 | 06:28 PM
Obviously the rims could have been changed, just check the VIN. It helps to know what model we are talking about, since the starter relay is not where you described on any 1988 and later XJ6.
Old Jul 21, 2009 | 07:32 PM
TheRooki3's Avatar
ok will do....i'll post it tonight once i get home...sounds corny (and probably not too smart but....) i can't wait to know what kind of jag i got,lol..... that's coming from somebody that has plenty of experience with different kinds of vehicles...
Old Jul 21, 2009 | 07:50 PM
Everything else is a car that is foreign to me.
Old Jul 21, 2009 | 10:24 PM
TheRooki3's Avatar
the 10th character on the VIN# is a "P" ...sheesh what do i own?
Old Jul 22, 2009 | 02:13 AM
A 1993 Jaguar XJ6, and a diminutive intellect.
Old Jul 22, 2009 | 02:33 AM
Cadillac's Avatar
Finally Happy End lol
Old Jul 22, 2009 | 09:59 AM
ArmyJag's Avatar
Old Jul 22, 2009 | 10:16 AM
TheRooki3's Avatar
To be ridiculed in my own post wasn't something i wasn't ready to tolerate kind sir.....but i suppose i deserve that? ...Not too sure...just brand new to the Jaguar universe, and acquired one recently, on top of that when i originally posted here i, it was in xj6 threads, but i was relocated by the kind moderators here to the XJ40 threads, but on the back of my vehicle it reads xj6 (i have a straight 6 btw) ...so it's throwing/confusing me just a bit....and i got a bit excited perhaps...i mean/meant no harm, i was brought here like most members in a quest in trying to get this art on wheels running properly that's all....
Now that we have the year make model established thanks to JagtechOhio...i hope you will continue to aid me in finding a way to get this vehicle running...it looks too nice to be just parked that's for sure. Question for you kind gents....so with the 1993 Jaguar XJ6...any of those relays on the firewall go to the starter by chance?
Old Jul 22, 2009 | 10:44 AM
ArmyJag's Avatar
It was moved to the XJ40 forum since you own a XJ40. The XJ40 is model designator used by Jaguar for the 88-94 XJ6. The section you originally posted in is for the previous model. Hope that clears up the confusion for you.
I would pm christo here on the forum or post up in his thread for the JTIS download on your jag. It is a complete factory service manual and will aid you greatly in trying to track down parts and repair the starter system on your jag.
